Moving Stud In The Way Of Shower Valve. - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-05-2013, 08:14 PM   #1
Rewards Points: 77
Moving stud in the way of shower valve.
I'm installing a shower valve and a stud is right in the way of keeping it center. It's a load bearing wall and I want to remove the old stud and put 2 studs in. 1 on each side of the current one so I have space to center the valve and install bracing for the valve. The space is tight with pipes wires and I have no room for proper bracing as of now. Can I remove the 1 stud and put the 2 studs in ? Each new stud would be about 6 or 8 inches from the current one giving me about a foot or so to work. There is a second floor above and roof edge, Double top plate.
bryan1282 is offline   Reply With Quote
Old 12-05-2013, 08:30 PM   #2
Rewards Points: 89
My answer is............yes! Two is better than one, but I am no expert.
REXAMUS is offline   Reply With Quote
Old 12-05-2013, 09:26 PM   #3
Rewards Points: 14,312
I would not even brace it, just remove it.
Old 12-06-2013, 06:14 AM   #4
Rewards Points: 1,300
Since this is a load bearing wall, Think "window opening". Too be done properly you should frame it the same as a window opening would be with a header and jack studs.
danpik is offline   Reply With Quote
Old 12-06-2013, 09:17 AM   #5
Rewards Points: 77
That's a good idea I didn't even think of that.
I need the two studs anyway for the valve bracing so that's not flopping around in the wall. Imma use that window framing idea. Thanks!
Old 12-06-2013, 06:41 PM   #6
Rewards Points: 77
One more question, the span between the 2 new studs is now 10 inches. Shorter then I originally thought. 2x8 wood is used for the window in the same bathroom that is 24 inches wide. Doubled up 2x8 should be fine for a 10 inch span?
Old 12-06-2013, 07:35 PM   #7
Rewards Points: 336
Sure; if it's good enough for the window span it's definitely good enough for this 10" span.
JKeefe is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
soldering copper pipe on a shower mixing valve. Ed911 Plumbing 7 05-17-2012 09:27 AM
Shower valve for rainshower head Liv Plumbing 0 03-29-2012 10:41 AM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 06:46 AM
