Mounting A TV Wall Mount - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-18-2011, 04:29 PM   #1
Mounting a TV wall mount
My screws won't go all the way into the wooden stud, even after drilling (the drill did not want to go all the way in either). I am using 2" wood nails, and nothing I try to do to get the screws the rest of the way in works. I even tried nailing in a nail before screwing it in, but to no avail. HELP!
vhouse2 is offline   Reply With Quote
Old 08-18-2011, 06:41 PM   #2
Stairguy
Millertyme's Avatar
Rewards Points: 508
it sounds to me that you are hitting something in the wall...like a pipe. Try a different spot if possible.
Millertyme is offline   Reply With Quote
Old 08-19-2011, 08:03 AM   #3
Rewards Points: 5,336
Where is the wall? Basement? Condo?
You could be hitting concrete or a protective plate covering wires or pipes.
Scout around to see if there are pipes coming up from the floor below or there's a bathroom above. It will be easier if the floor below is a basement.
Provide some details of the situation before you drill anymore.
Ron
B. Franklin 1759
Old 08-19-2011, 08:31 AM   #4
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
What are 2" wood nails?
CoconutPete is offline   Reply With Quote
Old 08-19-2011, 09:22 AM   #5
I'll go out on a limb here and say, nails you put in wood.
Didn't you take the OP translation course?
Ron
B. Franklin 1759
Old 08-19-2011, 11:59 AM   #6
Rewards Points: 1,596
2" wood nails converts to 2" wood nails (must be a browser thing)
bob22 is offline   Reply With Quote
Old 08-22-2011, 08:50 PM   #7
Johnboy555's Avatar
I'm just guessing here...but..
Sounds like a condo or apartment with 1 bys furring on top of block firewall (been there, done that)
If that is the case... you can use long Tapcom screws to mount whatever it is you are mounting (a little more info would be very helpful)
They have to be pre-drilled and remember that the first 2" of the screw will be attached to very little.
Johnboy555 is offline   Reply With Quote
Want to mount a sconce on the wall where there is a stud pdp76 Electrical 24 04-01-2011 05:07 PM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 06:23 PM
Wall mount big screen- drywall patch Mudman Project Showcase 3 03-01-2011 05:46 AM
How to mount an enclosure to exterior wall with vinyl siding? biglaz Building & Construction 3 05-30-2009 10:13 AM
Mounting a TV "IN" a wall dchutnik Home Theater 3 01-25-2007 09:05 PM
