Mounting A Hanger For A Hoist - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-11-2009, 10:15 PM   #1
mounting a hanger for a hoist
I want to mount a bracket to my joist to hang a hoist or pulley from. My joist I want to attach to has been reinforced and is ready to go, but I'm not sure what to do. Do I just need a flat bar of steel with a hole in it to wrap around the joist? It sounds like I shouldn't screw into the joist because that may weaken it, but then what? Does anyone have any suggestions?
palooka is offline   Reply With Quote
Old 02-11-2009, 10:41 PM   #2
Registered User
Termite's Avatar
We need to know a couple things first.
1) what is the hoist going to be lifting? (Don't say engines)
2) what dimension are your joists?
3) how does the hoist hang? From a chain? Eye bolt? Etc...
4) when you say the joist has been "reinforced", what do you mean?
Pictures would help a great deal
Old 02-11-2009, 11:19 PM   #3
1. i'm just settin it up for general use. i just built the garage and they put up a center truss that was overbuilt to hold up to 500 lbs of standing weight. the bottom cross beam of the joist is like a 2x4 or 6. not sure. i don't have pics, sorry. and i don't know how to hang the hoist. that's my question. i thought i would make some sort of a "u" shaped flat iron bar that hung over the truss. the builder told me not to screw into the truss as it would weaken it. so i was trying to figure out how to hang something to attach a hoist or pully to. does that help clarify?
Old 02-12-2009, 12:50 AM   #4
Registered User
Termite's Avatar
Ahhh, got it. I'd think that you could have a welder make you a nice U-shaped steel saddle from some 3/8" or 1/2" steel bar stock that would slip over the truss and hang down a couple inches. A couple holes could be drilled in it to accomodate a shackle, to which you could hook the hoist.
Your builder is 100% correct about not drilling into the truss. A few nails won't hurt anything if you need to, but no holes and no bolts.
880lb hoist from garage ceiling etriad Building & Construction 15 02-26-2011 05:18 PM
Ceiling Fan mounting Big Bill General DIY Discussions 8 02-07-2010 09:07 PM
Mounting Ceiling Fan to Exposed Beam zero1niner Electrical 7 05-05-2009 12:41 PM
Mounting a flatscreen TV on a sheetrock wall TanMan Building & Construction 14 02-16-2009 05:26 PM
Mounting a Punching Bag reingam@hotmail.com Building & Construction 4 10-07-2007 08:37 PM
