Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 04-26-2009, 01:44 AM   #1
Moulding up against door trim
I need to know how to cut my moulding to fit nicely up against the existing door trim.
mommy5 is offline   Reply With Quote
Old 04-26-2009, 05:23 AM   #2
You measure the distance, accurately, and cut the wood.
Trick question?
Ron
Old 04-26-2009, 06:52 AM   #3
Remodeling Contractor
Use a saw and a ruler. Need a better description of your question.
Old 04-26-2009, 02:25 PM   #4
Moderator
Your answer is somewhere in here, watch at the bottom for limited preview:
http://books.google.com/books?ei=A9P...&sa=N&start=10
Be safe, G
Old 04-26-2009, 05:05 PM   #5
Old School
Willie T's Avatar
Your baseboard molding often looks like it is too thick to fit flush against the back side of the door casing because you are looking at the rounded edge of the casing. In actuality, if you cut the baseboard neatly and squarely, it will just fit in there without sticking past the front of the molding. A little caulking on your finger will help if the cut is not perfect.
HINT: It helps if you cut the baseboard just a tiny, tiny bit long....... you can always trim or sand it shorter, but you cannot add wood already sawn off.
Willie T
Old 04-28-2009, 11:34 PM   #6
Hi Mommy 5,
Please find another Website with real Professionals!
Only Wood Butcher Comments so far !
rayrabbott is offline   Reply With Quote
Old 04-29-2009, 10:15 PM   #7
"yeah...we do that!!!"
what is a "certified door installer"
i did not know there was such a title...pretty good
hey... measure, mark, cut, nail. get paid, the basis for what we do!!!
KOHNSTRUCTION is offline   Reply With Quote
Old 04-29-2009, 11:52 PM   #8
That's why they call you guy's Wood Butcher's you don't have a clue, about Manufactures Warranties. ( That's why they have classes to follow their Specs.
( Not your so called )
Any Fool follows your rules.
Come on reply show your ( IGNORANCE ).
Old 04-30-2009, 08:00 AM   #9
gravity always wins
Don't take your goats across the bridge, there's a TROLL under it.
Old 04-30-2009, 09:57 PM   #10
Mom.:
Using a preacher to mark the baseboard directly for the cut automatically compensates for an out-of-plum plinth or casing. The preacher is a home-made jig, easy to build.
Regards, rredogg
rredogg is offline   Reply With Quote
Crown Moulding and nailing davis_mc Carpentry 21 01-12-2010 11:52 PM
Best place for moulding? Bulk pricing troyce1 Building & Construction 1 01-14-2009 06:31 PM
Need tips for installing/painting moulding BradG Painting 3 02-04-2008 01:44 AM
Moulding options for badly warped wall? marc205 Flooring 4 01-21-2008 08:43 AM
Is it best to caulk new moulding edges before painting? Davo Painting 8 04-15-2007 12:12 AM
