Moulding Extension For Sliding Glass Door Trim. - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-17-2013, 01:34 PM   #1
Rewards Points: 337
Moulding extension for sliding glass door trim.
So when my new sliding glass door was installed the frame is proud of the drywall by about 1/8" to a max of 3/16". I would normally just put latex caulk in the gap but on this wall you would see this. I was thinking it would be better but a (PITA) to glue a piece of 1/4"x 3/8 flat pine on the back side of the moulding and hand plane it down to fill the gap. I only plan on doing this on the two side pieces of moulding. For the 8 ft piece on the top of the door I will just use shims every couple feet and then caulk it as you can see that edge. Any other suggestions?
thanks!
titan7 is offline   Reply With Quote
Old 05-17-2013, 06:53 PM   #2
kwikfishron's Avatar
Rewards Points: 1,018
How thick of trim are you using? Do you have a table saw? If the trim is thick enough you can simply rabbit out the trim on the frame side to make it fit.
kwikfishron is online now   Reply With Quote
Old 05-18-2013, 08:30 AM   #3
Rewards Points: 14,312
Many times I've used a compound square to mark a line 3/16 in from the inside edge of the jamb and used a random orbital sander with 60 grit paper to remove enough material to get the trim to lay flat.
Need Advice For Fun Project - liberating stained glass window jackson33 Building & Construction 9 03-08-2011 04:09 PM
Moulding Around Sliding Glass Door JRMN Building & Construction 8 08-03-2010 11:22 AM
Glass on greenhouse roof Flavio Building & Construction 16 07-15-2010 07:37 AM
Door Moulding Idea Help Vibber Carpentry 4 06-01-2010 07:51 AM
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 12:35 PM
