Mortise Jig - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-27-2011, 10:40 AM   #1
Mortise Jig
Where can I find a jig for use with antique mortise sets like the one seen here...
http://houseofantiquehardware.com/s.nl/it.A/id.3845/.f
The one I did find is for 1 3/8" doors, mine are a lot thicker.
Help
M
BorgsnMerrick is offline   Reply With Quote
Old 02-27-2011, 05:12 PM   #2
A door a day is all I ask
TheDoorGuy's Avatar
My first door mortise tool was called a Grumbach mortiser...I am
not sure about that spelling. It clamped to the door and held a
special 1" speed bore type bit nice and straight. You would attach
your drill moter to it and drill the first hole. Crank the handle and it
would move the bit up a little and you could drill another hole.
It worked pretty well but it's probably hard if not impossible to find.
The modern day way is of course the Porter Cable 513 mortiser...
Very cool tool but cost is about $1000 plus the adjustable face plate template.
Unless you have a bunch of them, you are probably better off laying them out
and drilling by hand.
Richard The Door Guy
www.thedoorguy.com
TheDoorGuy is offline   Reply With Quote
Old 02-28-2011, 04:01 PM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
If the picture is about actual size, I would do it with a plunge router. If there is any bevel to the edge of the door, I would clamp some blocks in place to make my router set correctly. And I would use an edge guide to keep my bit centered.
Old 02-28-2011, 09:36 PM   #4
Rewards Points: 5,336
You need a jig to do this. Check the local tool rental stores for this mortiser.
Another option, if you have a drill press, is to use a mortising attachment. They will go deep enough and the cut will be controlled.
They also sell bench top mortisers that will do the job. You just need to set it up with the door.
Ron
How to take these old treads off? Mechelle Flooring 26 10-26-2010 07:42 PM
looking for help with an old mortise lock Polecatt2 General DIY Discussions 12 09-19-2010 06:52 PM
Replacing mortise locks? chins01 Remodeling 6 07-16-2008 07:14 PM
Where can I find cams for a Medeco mortise cylinder? BradG General DIY Discussions 2 04-16-2008 03:14 PM
Prep for re-gluing mortise and tenons? gshock Carpentry 2 08-22-2007 11:38 AM
