Mono Truss - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-13-2011, 09:26 PM   #1
Mono Truss
I'm adding mono trusses all the way around a two storey house for looks only. I'm using them as a way to break up the height. I'm not sure what is the best way to build them or fasten them to the wall. I've attached an elevation of the house and my draft drawing. I would appreciate any advice.
ryllee is offline   Reply With Quote
Old 03-13-2011, 10:22 PM   #2
Rewards Points: 83
I think you would lag bolt two ledgers to the building where the top and bottom chord of the truss make contact. Then you are free to use joist hangers and screws/nails. Not sure if this is the correct method, but it is how I would do it.
rubberhead is offline   Reply With Quote
Old 03-13-2011, 10:55 PM   #3
Registered User
Rewards Points: 5,266
Contact your local Building Department before building these add-on to your house framing. They may require each framed and side sheathed with plywood, engineered ledger attachment design, etc. Nice for the paper trail for your Hopmeowners Insurance at a later leak or claim...
Gary
Old 03-14-2011, 10:53 AM   #4
Thanks for the advice!
Attic truss space PrecisionVision Roofing/Siding 0 11-18-2010 11:30 AM
Pre Fabricated Truss for Patio roof seth Building & Construction 6 07-18-2009 08:23 PM
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 09:45 PM
2nd story ledger to floor truss fisherk Carpentry 1 10-18-2008 01:08 PM
Gambrel Truss Dormer and Ladder Framing? fauer Carpentry 3 09-30-2007 08:36 PM
