Mollys - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-08-2013, 08:38 AM   #1
Rewards Points: 2,072
mollys
If you need to move a molly, just 1/2", how close to the old hole is safe to put another hole?
My daughter hung the bathroom mirror, but didn't use level, just measured from top and bottom, which were off. Now the mirror is crooked. I'm afraid if I move one molly 1/2" that it will pop a hole since it might be too close to where the other molly was.
Or, if I leave the one molly where it is, maybe that will add support and I can just add another molly above it? (rather than remove it and patch the hole).
Worried cause a girlfriend put so many holes in a wall rearranging a curtain rod that she had to call a drywaller when a big chunk of drywall fell out.
1/2" isn't much but it bugs me.
thanks
Startingover is offline   Reply With Quote
Old 04-08-2013, 08:44 AM   #2
Rewards Points: 13,300
Your right most likly it's going tp bust out.
It is a drywall wall right?
Got a picture of what your trying to do?
Pictures and mirrows should be hung using two points on the wall, this way they can be leveled and will not keep swinging out of level.
Old 04-08-2013, 08:48 AM   #3
thanks Joe,
yes, it is drywall.
This mirror has two 'eyes' on each side of the mirror frame, and a warning, "do not use picture wire".
We got rid of the builders giant mirror and put a smaller decorative mirror over the sink. I'm just glad it's the guest bath because I don't have to look at it very often.
Old 04-08-2013, 09:04 AM   #4
are the eyes on the back of the mirror screwed on by any chance? can you move one of them up or down ?
The Following User Says Thank You to DannyT For This Useful Post:
Startingover (04-08-2013)
Old 04-08-2013, 09:08 AM   #5
danny,
wow, aren't you clever. I never thought to check the mirror eyes. Will do it right now.
(I'm from Ohio too)
EDIT: checked the frame and not sure I should mess with the screws holding the eye's on. Just realized (altho it's pretty) the frame looks like wood but is plastic.
Old 04-08-2013, 09:37 AM   #6
AHH, SPANS!!!
Rewards Points: 1,166
can you make an extension wire loop out of electrical wire or similar that hangs off of the low sided eyelet or high sided drywall insert with screw and then hangs from the screw?
hand drive is offline   Reply With Quote
The Following 2 Users Say Thank You to hand drive For This Useful Post:
r0ckstarr (04-08-2013), Startingover (04-08-2013)
Old 04-08-2013, 01:40 PM   #7
handdrive,
aha! This is something I might play with and experiment with. That didn't occur to me either. I think this could work.
thanks.
The Following User Says Thank You to Startingover For This Useful Post:
hand drive (04-09-2013)
Old 04-08-2013, 02:37 PM   #8
Roofmaster
Rewards Points: 2,172
Originally Posted by Startingover View Post
handdrive,
thanks.
Sounds like one of those cases of tunnel vision. I get them all the time.
Here we have a rare case of two wrongs making a right, or a plumb, as it were.
The Following 2 Users Say Thank You to jagans For This Useful Post:
Hanging curtains... KWoss Drywall & Plaster 2 11-22-2011 03:26 PM
