Molding Under Vinyl Siding - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-14-2009, 08:35 AM   #1
molding under vinyl siding
Help! The wood molding that goes between the vinyl siding and brick on my house is rotting and I need to replace it. I thought it was just some type of molding that could just be taken off and a new one nailed back on, but someone told me that it goes up underneath the siding and that the siding has to be lifted up and replace the wood, then put the siding back in place. I was hoping that my 14 year old son and I could do this project. I can't afford to hire someone and it might take a while to get it finished. Is there an easy way that someone could tell me how to fix this?
aharbin is offline   Reply With Quote
Old 05-14-2009, 04:32 PM   #2
Rewards Points: 5,336
Post a picture of the molding and the wall.
Ron
Old 05-14-2009, 04:53 PM   #3
Household Handyman
Rewards Points: 1,408
Ron is right in this case, a picture is necessary. Off hand I can't think of any molding that would go under the siding and be exposed at the same time. I'm picturing the vinyl siding being in J-channel, as it should be, and maybe the J-channel being up against the brick or wood molding. If you can't post a picture maybe you are a better artist than I am and could provide us with a good drawing of this. Let's work together and see if we can help you. David
Old 05-14-2009, 05:42 PM   #4
What do you mean, "In this case"?
Was that a shot?
Ron
Old 05-14-2009, 09:12 PM   #5
Registered User
Rewards Points: 5,482
I don't know, but he's almost yelling. I had to back up my bi-focals to read it!
Be safe, G
Old 05-14-2009, 09:19 PM   #6
Builder and Remodeler
JohnCarpenter's Avatar
It sounds like a brick freeze at the junction. Yes the siding will have to come off, but you should only have to remove the bottom piece. The siding snaps together and you will have to unsnap the first and second row. Lift the second row out of the way to remove the nails in the first row. Remove the first row of siding and j channel. Then replace the brick freeze.
_______________
Johnny Jackson
http://www.jljacksonremodeling.com
JohnCarpenter is offline   Reply With Quote
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 12:32 PM
Vinyl siding over cedar siding dbldee20 Remodeling 8 02-21-2009 07:06 AM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
