Molding To Chair Railing - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-09-2011, 08:56 PM   #1
Molding to chair railing
I am doing wallpaper and a chair railing. I have an outside corner in the room where I want to run a thin strip of molding from floor to ceiling because the outside corner is very uneven.
My question is this. Should the chair railing run continuous and the molding be split coming down from the ceiling to the floor or should the molding run continuous from floor to ceiling and have the chair railing butt to each side the floor to ceiling molding on this outside corner?
joemcny is offline   Reply With Quote
Old 04-09-2011, 10:01 PM   #2
I think mitering the chair rail around the corner and splitting the floor to ceiling would look cleaner especially if the molding (floor to ceiling) is kinda thin. can you clean up the corner with corner bead and good ole joint compound in place of molding? really its personal preference try mocking it up both ways with scrap cut offs.
airborne82 is offline   Reply With Quote
Old 04-10-2011, 06:58 AM   #3
why not just remove the old corner bead and put a new one in that is straight?
TBFghost is offline   Reply With Quote
crown molding and chair rails hollyjo213 Kitchen & Bath Remodeling 2 10-02-2009 12:56 PM
colors of crown molding and chair rail dolphin800 Interior Decorating 7 05-13-2009 07:53 PM
Painting baseboard molding same color as chair rail and crown molding Barb Wieczynski Painting 4 04-11-2009 08:32 AM
Installing Chair Railing vball Carpentry 3 03-30-2009 08:56 PM
How to fix broken step railing? robertr4836 Carpentry 2 04-18-2008 11:19 AM
