Moisture In Sheathing - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-27-2011, 04:22 PM   #1
Moisture in sheathing
What is the average moisture content (%) of roof sheathing in an attic?
Mucluk is offline   Reply With Quote
Old 12-27-2011, 05:03 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
A most lumber is kiln dried, there shouldn't be any moisture.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-27-2011, 06:04 PM   #3
Rewards Points: 6,652
Right no my attic shows 57% humidity. Some days it is as low as 13%. So in theory yes, there could be moisture in it, but it should not hold it if the house attic space is well ventilated.
Old 12-27-2011, 06:52 PM   #4
Disabled wood vet
titanoman's Avatar
If the sheeting is osb, as opposed to plywood, it is lightly sealed from moisture from the factory also.
Old 12-27-2011, 07:08 PM   #5
I was going to say, doesn't it have carnuba wax or the such on it, where as with ply unless it is outdoor, basically has nothing.
Old 12-29-2011, 08:54 AM   #6
Mold!! Let's kill it!
Rewards Points: 2,012
That would vary greatly with your location (which you have not provided). Moisture content in sheathing can vary from one side of the roof to the other depending on exposure to the sun, air flow within the attic, etc. A probing moisture meter will tell you. Relative humidity in air is different than percentage of moisture content in wood. RH in air can have an effect on moisture content in wood, but 57% RH is not going to give you 57% moisture content in sheathing, rafters, etc. Percentage of RH is temperature driven. There will always be a certain amount of latent moisture in the sheathing.
Old 12-29-2011, 09:05 AM   #7
My moisture meter is giving readings up to 15%. Is that high for sheathing in an attic?
Old 12-30-2011, 07:35 AM   #8
No. Roof sheathing can vary some because of miniscule amounts of condensation under the shingles. Sheathing probably runs 9-15% depending on your location. Processed materials like OSB or plywood tend to run slightly higher than solid wood because the glue will trap a slight amount of moisture in the wood fibers. Make sure your attic ventilation is working properly.
Old 12-31-2011, 05:53 AM   #9
Retired carpenter
Wood with 15% moisture content is considered "dry" for all practical building purposes.
abracaboom is offline   Reply With Quote
High moisture in slab, should I put down a barrier for travertine? help! eezeekial Tiling, ceramics, marble 15 11-21-2011 05:14 PM
Cleaning brush StevenH Painting 19 02-05-2011 11:13 PM
Basement Moisture, what's this? bergerdude Building & Construction 1 06-11-2010 01:27 PM
Moisture meters and radiant concrete slab snowydaysrock Flooring 7 01-21-2009 06:33 AM
Moisture on Inside of Sheathing elburritoloco Building & Construction 18 01-19-2009 08:16 PM
