Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-24-2011, 11:58 AM   #1
Angry
mobile home floor repair
Need to replace floor under toilet in a mobile home. Unfortunately I need someone licensed to work on mobile homes!
Or I need detailed instructions to do it myself. See a lot of videos on utube, but none with any sound, or explanation, cautions, etc.
69mobile is offline   Reply With Quote
Old 01-24-2011, 12:20 PM   #2
How different is it from a floor in a house? There are supports under the flooring material that hold up the subfloor. On top of that, you have the finished floor.
Can you take pictures of the floor? Try to get under the mobile home if you can.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
69mobile (01-24-2011)
Old 01-26-2011, 11:39 PM   #3
I've had to deal with this. The floor is particle board, and as you know it turns to mush when it gets wet.
A lot of folks will just replace the whole floor with plywood. Just go around the edge with a skill saw set to the depth of the particle board and yank it up. You can also just do an area around the damaged spot. Just be sure to support the plywood patch you put in to replace it.
I wouldn't go under the house... there's nothing to be gained there. You can see where the joists are when you pull up the vinyl, carpet, whatever. When you cut into the "bottom board" (the plastic like stuff under the trailer), you'll have a hell of a time closing it back up... duct tape won't do it.
almostnormal is offline   Reply With Quote
Old 01-27-2011, 12:09 AM   #4
You've been a great help almostnormal. Thanks.
Need advice on remodeling/renovating a prefab (mobile) home countrylifemom Remodeling 47 03-20-2013 10:48 AM
Replacing Mobile Home Package AC Unit jack roscoe HVAC 3 05-24-2010 03:13 PM
running electric under mobile home brianbrianj Electrical 6 05-09-2010 04:49 PM
deck for a mobile home rln17 Building & Construction 2 09-09-2008 05:51 PM
Mobile home electric. RobertS Electrical 7 02-27-2008 01:25 PM
