Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 02-15-2010, 03:59 PM   #1
Mitre Saw: what does "Max cross cut" mean?
Can anyone help me understand what the first number on a mitre saw spec means. Looking at one that states it has a max cross cut of 92 x 310mm. understand the 310mm is the length, is the 92 the max depth that the saw will cut?
imac is offline   Reply With Quote
Old 02-15-2010, 04:03 PM   #2
Love for Construction
<*(((><'s Avatar
To get the max cross-cut (how large of lumber will it cut in one pass) you have to have how wide the lumber is by how deep the lumber is.
So the max that saw will cut is 92mm deep X 310mm wide (or ~3-1/2" by 12-1/4"). Must be a sliding miter saw, to have that capacity.
<*(((>< is offline   Reply With Quote
Cross Timbers Decking thebluick Building & Construction 23 04-16-2013 03:30 PM
buying metal cross braces Lturgeon Building & Construction 8 09-01-2009 04:55 PM
removing joist cross bracing williemyers Building & Construction 1 08-11-2009 02:20 PM
How to cross cut a mitre on a 1x6 beerdog Carpentry 1 05-28-2009 08:10 PM
Ok to use a sanitary cross in a wet vent? peeks Plumbing 1 10-03-2005 05:35 PM
