Mitre Corners - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-28-2012, 05:40 PM   #1
mitre corners
how to cut trim when the angle is bigger than 90
dodge1972 is offline   Reply With Quote
Old 03-28-2012, 06:05 PM   #2
Too Short? Cut it Again!
Not sure I understand what you are asking? Are you saying your saw will only go 90 or something?
Otherwise you need a cabinet makers protractor or mitre finder. Simple tool of quality will be $20 on up to something like this for $200 if you want to impress your friends. I played with a great crown moulding Android app over the weekend if that is what is baffling you.
Old 03-28-2012, 06:07 PM   #3
outside corner the angle is greater than a 45 how make the cut thanks
Old 03-28-2012, 06:12 PM   #4
kwikfishron's Avatar
Rewards Points: 176
You can cut any angle you want with a chainsaw.
A little more detail (or pictures) with your question would help.
kwikfishron is online now   Reply With Quote
Old 03-28-2012, 06:22 PM   #5
An ice sculptor heard from!
I do think we need to know more of what you are cutting, what you are trying to cut it with, and I guess why? I am just assuming trim of some kind.
Old 03-28-2012, 07:38 PM   #6
Haverhill Trade 1965
Miter cuts are always 1/2 the angle of the wall angle etc. 45 degrees is
45divided by 2 = 22 1/2. If the miter is on the right put it in the miter saw upside down and cut the opposite end (left end). "upside down and backward" the old timers say.
Duckweather is offline   Reply With Quote
Old 03-28-2012, 08:05 PM   #7
KemoSabe
loneframer's Avatar
I screw a block of wood to my mitersaw table that has a 45 precut on the end, then set the miter to the combined angle I need. If I need 67 degrees, I set the saw to 22. Combined with the 45 already on the block, I get the angle I need.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 03-28-2012, 08:06 PM   #8
Rewards Points: 176
No Ice, just Cedar and D Fir logs
Old 03-28-2012, 09:42 PM   #9
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
just as lone mentioned. if you need to cut a piece greater than the capacity of your saw simply shim the peice of wood so its creates the angle
another example of this is when cutting door casing. i always back cut my casing on a bevel of 1 degree so the face of the joint is air tight. this can be done by setting the saw on a 1 degree bevel or you can put a 1 1/16" sliver of wood underneath the peice of wood being cut
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Willie T (03-30-2012)
Old 03-29-2012, 07:12 PM   #10
Good advice all. Also if the angle is just a degree or two most saws now seem to cut more than 45. Mine cuts 50 one side 55 the other. Must be for walls that are more out of square on one side of the corner?
Curved corners where drywall meets? SouthGAreno Remodeling 12 01-17-2013 04:10 PM
recommend a book nvr2low Drywall & Plaster 9 12-22-2011 12:37 AM
Best way to make 45 degree mitre jig BobS0327 Carpentry 7 09-22-2010 12:53 AM
cement board corners ponch37300 Kitchen & Bath Remodeling 3 01-25-2009 06:50 PM
How to mitre bullnose corner bead?? Arbs Building & Construction 3 01-28-2008 01:32 PM
