Miter Saw Kickback With Oak Quarter Round - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-07-2012, 05:36 PM   #16
DIY staff
Rewards Points: 7,174
Remember what Lone said about letting the blade stop before raising it---
BigJim (01-07-2012)
Old 01-09-2012, 01:10 PM   #17
Crusty Old Dude
Big Stud's Avatar
Or you can pull the piece away from the blade after it is cut before letting go of the trigger. I always use a sacrificial fence setup for small moldings, I always called it a "shooting board"
All the best to you and yours, Tom
Big Stud is offline   Reply With Quote
Old 01-09-2012, 02:53 PM   #18
Ole Wood Worker
BigJim's Avatar
Rewards Points: 280
But the small piece will still be there to get slung to who knows where.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-10-2012, 05:17 PM   #19
Thumbs up
Originally Posted by loneframer View Post
I like to use a sacrificial piece of material against the fence when cutting small trim profiles. Most times the air movement caused by the spinning blade is enough to draw a small cut-off into the gap between the fence components and ruin the moment.
Exactly what I do
mrgins is offline   Reply With Quote
Old 01-11-2012, 08:52 AM   #20
Originally Posted by jiju1943 View Post
Loneframer is dead on, I also have the 12 Dewalt 708 and have the same problem no matter what blade I use. I always take 2 pieces of 3/4 plywood 3 inches tall and the length of the saw table and screw, one to the edge of the other piece of plywood forming a 90 bed like is on the miter saw. I clamp the plywood onto the bed of the miter saw and cut the small trim on the plywood. Not only does it not sling parts all over the place the plywood gives you a good reference point to cut the trim from.
The reason it slings the small pieces is the piece has no support on the back after being cut, and will move while the blade is spinning and the blade will catch it and throw it. It will startle you if you aren't expecting it.
Yes, I had a similar problem years ago. I started using one of those wood holder things that you could move up and down so that the wood wouldn't move after or during the cut. I didn't have much problem after that. I tried to find a picture, but IDK what they're called to show you. It's basically a saw horse with the height being adjustable, so however tall your saw is, you match the height and set your wood on that and it feeds it to you.
BaltimoreBamBam is offline   Reply With Quote
Tags
kickback , miter , molding , oak , safety
Quarter Round with New Carpet ryanb4614 Flooring 4 11-21-2011 09:20 AM
Quarter Round for hardwoods - White or match the floor? mr_ekco Flooring 6 02-22-2011 06:00 PM
small quarter round moulding mf915 Flooring 11 09-30-2009 12:14 AM
quarter round + door frame= headache fenceman Flooring 3 02-15-2009 02:28 PM
Quarter round in basement? xray328 Carpentry 5 07-24-2007 06:08 AM
