Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 07-08-2009, 10:26 AM   #1
Default Miter Saw Confusion
Hi, I need help.
Just laid a floor and have to put in baseboards where there are none at kitchen cabinets. I found the miter saw and know to cut 45 degree angles. The problem is the saw won't go high enough to stand the wood up. I can only get the baseboads to lay flat on the metal, on top of the grooves under the saw. This won't do the right cut. The wood has to stand up to get the cut but the saw sits in a frame and only allows a few inches to move up and down. How do I make my 26 cuts? Home Depot won't miter for free or for $$$. I seem to remember hardware stores used to do that sort of thing. . .and gas stations used to check your oil, put air in tires and wash windows . . .
Thanks, Patti
Blue Spruce is offline   Reply With Quote
Old 07-08-2009, 10:55 AM   #2
Home Remodeler
You should be able to lay the base flat an cut a 45.
mikey48 is offline   Reply With Quote
Old 07-08-2009, 11:29 AM   #3
Not if it isn't a compound miter saw.
If you're careful, you could probably do it with a circular saw and a speed square for a guide.
Old 07-08-2009, 12:03 PM   #4
Drywall contractor
I really don't think hardware stores used to miter cut lumber..... You could rent a saw of the proper size at a tool rental, buy a larger saw if you have more upcoming projects to justify the expense (look on Craigslist for a used one), borrow one from a neighbor, or just hire someone to install the base. Find a reliable handyman and it shouldn't cost too much. Ask at the local lumber yard or ask a neighbor. Always check references.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 07-08-2009, 12:22 PM   #5
Old School
Willie T's Avatar
It sounds like Patti may be trying to use a HAND miter saw.
Patti, this makes it tough on you. Try to buy (try a pawn shop) power (electric) miter saw, or borrow one from someone.
Willie T
Old 07-08-2009, 09:44 PM   #6
or hire a carpenter. construction workers are hurting right now
II Weeks is offline   Reply With Quote
Old 07-10-2009, 12:32 AM   #7
Patti, you are definitely using the wrong tool. You might be able to rent a power miter saw at a tool rental. Be good to have for a job like this.
hayewe farm is offline   Reply With Quote
Old 07-10-2009, 01:29 AM   #8
Default miter saw
probably the best thing to do is to cope the joints. You will also get a better fit in most cases. Bring the end of one piece to meet the side of the other piece and trace the outline with a pencil - then cut it with a jig saw of coping saw.
For more woodworking tips visit http://www.woodworkingtipsandtools.com
drbob is offline   Reply With Quote
Old 07-10-2009, 01:36 AM   #9
How tall are these baseboards?
What type of miter saw do you have? The plastic box thing is not a good one.
I use a manual miter saw and can cut wood up to about 4 inches high. (Although it takes a while). It is the 50 dollar manual miter saw, Stanley. I'm scared of the power ones.
I did my baseboards in 3 pieces. The 1x flat board cut straight with a jig saw and put in place. Then a top molding strip (I used cove) cut at 45 and affixed to the top of the 1x along the wall. Then the shoe molding for the bottom gap, also cut at a 45.
Good luck.
drillbit is offline   Reply With Quote
More On This Topic
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip, we are going to demonstrate how to cut crown molding on an outside corner with a miter saw. It is pretty similar to cutting on the inside corner, so if you just change your miter... Read More »
In order to install base molding, you must be familiar with inside and outside corners. Inside corners and outside corners cut totally opposite from each other. In the steps below, you'll see how to manage the cutting of inside corners. Read More »
Hi! This is Bobby Hester on behalf of expertvillage.com. In this next clip, we are going to demonstrate how to cut crown molding on an inside corner. Crown molding sits against the wall usually at a 38 degree or a 45 degree that depend on the type of... Read More »
Hi! This is Bobby Hester on behalf of expertvillage.com. In this clip, we will be demonstrating the basic functions of a miter saw. A miter saw allows you to make perfectly accurate straight miter and bevel cuts time and time again. A straight cut is a... Read More »
Perhaps you have a piece of trim that you want flush with a cabinet. If it's square with the wall, you'll need to make a 90-degree miter saw cut to match the trim to the cabinet. Making a 90 degree miter saw cut is fairly straightforward as long as you... Read More »
Replace miter gauge of B&D table saw nathan.tran Tools 0 10-19-2008 02:32 AM
miter saw 45 Deg how too turn table? chinese_lover Carpentry 9 07-22-2008 10:58 PM
Need advice or feedback on miter saws mwehnes Carpentry 10 02-21-2007 10:48 AM
Miter saw stand jonesiera Tools 9 09-03-2006 08:24 PM
Question on miter saws Doug Crf Tools 2 06-22-2006 08:42 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
