Miter Saw Angle Cut Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-15-2011, 08:56 PM   #1
Rewards Points: 107
Miter saw angle cut question
Ok, I realize that this is a pretty dumb question, but here goes. I am getting ready to replace my deck rails with a composite system. For the stair spindles, I will will have to cut the angles and as I look at the old ones still up, I see that the cut of the angle on the top is opposite from the one on the bottom. I plan on doing a mock up with scrap 2x2's before I cut the good stuff, but is there a good trick or technique for remembering how to cut the angles opposite from each other on each end?
thanks
Ranger1227 is offline   Reply With Quote
Old 05-15-2011, 09:24 PM   #2
Try using an angle tool, check the angle of the old one then use that measurement to duplicate the new piece. Or just remove an old piece and use that as a guide.
jlazer99 is offline   Reply With Quote
Old 05-16-2011, 07:55 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
When you get the angle set correctly, mark your saw with a sharpy so you can go back to that setting, or cut all of your pieces at one time. Alway remember that the long ends of the miters are always opposite each other and always the same angle.
LP / NG - Unusual Question... Peter B. Appliances 8 04-09-2011 09:59 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
hrv question indep HVAC 3 07-17-2008 11:39 PM
Staircase wainscoat angle DIYPRO Carpentry 5 04-08-2008 05:12 PM
Brick Veneer on steel angle iron sandyman720 Building & Construction 3 07-09-2007 09:21 PM
