Miter Saw - Am I Using It Wrong, Or Is It Not Up To The Task? (Molding) - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-27-2013, 08:02 PM   #16
Stairguy
Millertyme's Avatar
Rewards Points: 508
Looks to me like your material isn't flat, as seen in the second picture. Also if that's a 12" saw there will more than likely be some blade wobble. Is your fence square to the table?
Millertyme is offline   Reply With Quote
Old 10-27-2013, 08:09 PM   #17
Dave88LX's Avatar
Rewards Points: 564
New blade didn't help.
I've cut many different pieces and sections of material and it's not getting any better. With the DeWalt, that last inch or so on the 45* miter, the blade cuts down to the left for some reason. I forget what it does on a 45* miter the other direction.
Dave88LX is offline   Reply With Quote
Old 10-27-2013, 08:24 PM   #18
JOATMON
ddawg16's Avatar
Rewards Points: 812
I see several potential issues.....
It looks like your stock is not sitting square on the table....what are you using on the end to support the stock? I have an adjustable roller that I use if I'm not using my fixed table. If your stock rocks either up or down, your going to have a bad cut.
Second....I personally wouldn't cut it vertical like that. I prefer to tilt the head 45 deg and lay the stock flat.
Old 10-27-2013, 08:41 PM   #19
Dave88LX's Avatar
Rewards Points: 564
Good eye/info. That was just a mock-up for a picture. The stock is sitting flat on the table. This cheap flimsy stand though, I need to adjust the height as I get closer or further to account for the weight flexing the arms. Further out, it sags more. Closer in, I need to lower it so it doesn't sag so much. All that to say it's properly supported during the cut, I have to check each time since the old stand moves.
This DeWALT stand is much much better, much sturdier.
You can see the cut it makes with this DeWALT with a 45* bevel cut...not pretty at all. It's curved. From what I can see and watch, most people cut it straight down against the fence to do a 45* miter? Survey Says?
Old 10-27-2013, 09:14 PM   #20
Stairguy
Millertyme's Avatar
Rewards Points: 508
So is it making a bad cut laying flat on table or standing on edge?
Old 10-29-2013, 11:27 AM   #21
Dave88LX's Avatar
Rewards Points: 564
Both.
Standing on edge, bevel @ 0*, miter @ 0*, it makes a perfect cut.
Standing on edge, bevel @ 0*, miter @ 45*, it makes this cut. It cuts down straight-straight-straight, then the last 1-1.5 inches, it hooks left.
Laying flat, bevel @ 45* (head flopped left), miter @ 0*, it makes this cut. You can see it's taking more out of the middle than the outside edges.
Old 10-29-2013, 12:24 PM   #22
Ole Wood Worker
BigJim's Avatar
Rewards Points: 116
The bottom picture shows the trim is cupped, lay a straight edge across the face and see if it is flat or not.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 10-29-2013, 01:07 PM   #23
Dave88LX's Avatar
Rewards Points: 564
OK I will do that. I noticed the rear profile of the new molding I bought is different than the old. You can sort of see the old profile in that bevel cut. The middle is recessed.
This is the new back. Just a different company/mill? Better design?
Tiling up to door molding 99miles Building & Construction 4 08-10-2009 10:48 PM
Is this the wrong type of molding for walls? dma550 Carpentry 8 07-15-2009 10:55 AM
Front door side lite plastic molding Franky5 General DIY Discussions 3 05-31-2009 08:01 AM
Installing Crown Molding in Plaster hoboing Carpentry 8 05-25-2008 08:11 AM
Question on miter saws Doug Crf Tools 2 06-22-2006 07:42 PM
