Miter Saw - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-21-2008, 10:41 PM   #1
Talking
Miter Saw
I will be installing new moulding and hardwood floors over the next few weeks and thought it would be an excuse to buy a new tool. I'd like to buy a miter saw, but don't think I need a $500 Dewalt with a 12" blade. I'm thinking 10" cover any future needs. I'm curious about which brand might be the best value. I've read about Rigid and they seem decent, but any thoughts would be welcome.
Thanks.
brucetackett is offline   Reply With Quote
Old 02-21-2008, 10:59 PM   #2
Bosch 3918B 18-Volt Ni-Cad 10-Inch Cordless Compound Miter saw
Other products by Bosch $193.05 - $346.00 with stand and all
xkempx is offline   Reply With Quote
Old 02-21-2008, 11:05 PM   #3
this is my 1st pick, little more but hay if you ever want to sell it after. it still worth $$$$$
Old 02-21-2008, 11:08 PM   #4
Question
Thanks. What's the brand name of the second pic you posted.
Old 02-21-2008, 11:10 PM   #5
Makita
10 Inch Compound Miter Saw Features:
  • Performs compound cutting operations
  • Dual post compound pivoting arm
  • Bevel cuts up to 45° to the left
  • Miter cuts 0-45° left and 0-52° right
  • Positive stops at 9 settings; 15, 22.5, 30, 45°, right or left and 0° (90° cuts)
  • Powerful 15 AMP motor
  • Weighs only 24.2 lbs. for easy portability
  • Pivoting fence flips for supporting larger stock
  • Shaft lock for easy blade changes
  • Precision machined aluminum base
  • Arbor: 5/8"; 4,600 RPM
  • Double insulated
Old 02-22-2008, 07:05 AM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
A 12" blade allows you to cut wider stock.
If you need a saw for general all-around use, a 10" is the way to go.
We have 5 of them that we use most often, over our other sized and type compound saws.
On the professional side:
10" is more portable for standard interior trim installs.
12" is more universal, for wider exterior-trimwork.
- Build Well -
Miter Saw Blades \ Crown Moulding Jigs Discussion WorkOnIt Carpentry 3 06-17-2007 04:50 AM
Need advice or feedback on miter saws mwehnes Carpentry 10 02-21-2007 08:48 AM
10" miter saw fred430 Tools 6 11-27-2006 08:16 AM
Miter saw stand jonesiera Tools 9 09-03-2006 06:24 PM
Question on miter saws Doug Crf Tools 2 06-22-2006 06:42 PM
