Misdrilled A Hole In My Floor - Best Way To Fix It? - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-17-2013, 09:32 PM   #1
Dave88LX's Avatar
Rewards Points: 564
Misdrilled a hole in my floor - best way to fix it?
Measure twice, cut once. Mixed up my 9/16 and my 9/32.
How should I fix this? Baluster is not installed yet.
Amount exposed.
Dave88LX is offline   Reply With Quote
Old 03-17-2013, 09:35 PM   #2
Rewards Points: 6,652
The wall, base & shoe molding will hide that in the 2nd picture. The first will be harder, due to you will have to get a plug cutter, to cut off of the same material for both types of wood material. Would take some work to make them blend in, but could be done.
Old 03-17-2013, 09:42 PM   #3
Dave88LX's Avatar
Rewards Points: 564
Same hole, the second is just with the baluster in the hole...
Also hit a couple screwheads with the $10 Forstner bit, made it quite aggravating to finish up the job.
Old 03-17-2013, 09:55 PM   #4
Rewards Points: 320
One piece plug. Cut a false joint in the middle and stain each half. Nosing side looks like naturally aged clear maple. Shellac might match it. Floor side looks like one of the colors in the minwax color chart.
carpdad is offline   Reply With Quote
Old 03-17-2013, 09:58 PM   #5
Dave88LX's Avatar
Rewards Points: 564
Whoa...that's fancy. A lot better than "sticking some filler in the hole." that I was thinking of. For some odd reason, the nosings I got don't quite match the Bruce cinnamon colored maple that we put down. Was supposed to, but, not quite close. I am using Varthane summer oak for the handrail and newel post, and it matches the planks pretty good. The nosing is a bit more orange though.
So I need this here?
http://www.amazon.com/CMT-529-191-31...22+plug+cutter
Old 03-17-2013, 10:43 PM   #6
Yep. Be like any other tool that most of us have sitting on our benches, or in the drawer. Bought for a small one time only job, and there she lies. Spent $42 on a Ideal BX/MC cutter from our local Electrical warehouse store front, only because I did not feel like using a hacksaw for something that I could do quicker with the cutter. Next time I will probably use it, is when we redo the kitchen, and I wire up the disposal, and then it will go back on the work bench of all of the other tools that I throw up on there, due to currently in the middle of a job in the basement with a water heater this week.
Old 03-17-2013, 10:58 PM   #7
Roofmaster
Rewards Points: 2,172
You should have attached the balusters to a separate base plate that was screwed down then plugged.
Old 03-17-2013, 11:18 PM   #8
how far apart are the balusters. the holes look way to far apart to meet code.
Old 03-18-2013, 12:02 AM   #9
Dave88LX's Avatar
Rewards Points: 564
Holes are 5 3/32" center-to-center. Balusters are 1 3/8" wide.
5 3/32" - 1 3/8" = 3 23/32" gap.
I had read different things pro/con about a base plate. I thought with this open plan and overhang, that it would look better without a bottom rail. Is it SUPPOSED to be in a bottom rail? Or personal preference?
Old 03-22-2013, 11:36 AM   #10
Dave88LX's Avatar
Rewards Points: 564
In hindsight, I should have. I thought these square balusters would look OK directly on the wood floor like "real" wood ones do. These square balusters are actually ~20 layers of wood, and not all the bottoms are perfect. Some imperfections. Those could have been hidden in a base plate with fillets.
Old 03-22-2013, 11:38 AM   #11
Dave88LX's Avatar
Rewards Points: 564
Basically I did that, minus the staining two separate sides. Just used a plug out of a scrap piece of wood, and cut the false joint in it. For a house I intend to rent out, it'll work fine. Great tip thank you.
Old 03-22-2013, 12:34 PM   #12
Nobody is ever going to see that unless you go pointing it out.
Looks good to me.
oldhouseguy is offline   Reply With Quote
Repair Small Hole in Vinyl Siding Silkcityflorida General DIY Discussions 12 04-08-2013 04:34 PM
Cutting Hole for Bathroom exhaust jburchill Kitchen & Bath Remodeling 14 04-16-2012 12:55 PM
Hole in clapboard allowing birds to nest GarfE Pest Control 1 04-16-2012 12:14 PM
patching hole in 8" concrete block BlueBSH Building & Construction 5 08-09-2011 07:55 PM
Need to enlarge hole in wood top plate: or use flex with minimum OD. mysterylectric Electrical 3 08-09-2011 03:52 PM
