#1 |
Mild termite damage to wall studs
We ended up tearing a whole wall of rotted drywall out due to old termite damage. The drywall looked fine before we removed the baseboards...but once we realized how bad it was, we went ahead and took it all down. It seems that the studs are fine. I did find a few spots like this where you can see that the termites did affect the stud a lite. Is it okay if we put up new drywall over damage like this? It doesn't seem to be bad enough overall to replace the studs. Any suggestions? Here is also a photo of the whole wall...and yes, the termites were treated and are dead and gone!
#2 |
uva uvam videndo variafit
The one picture looks pretty bad. I wouldn't replace the studs, but I would go ahead and add another stud next to the damaged one. I wouldn't require much effort and you have peace of mind after the drywall is up.
#3 |
The drywall screws attach into the first 1" of the wood. As Wireless said, sister good studs to the damaged ones or the drywall won't attach to anything. Longer screws wouldn't be my solution because of the crush factor in the bad wood.
Ron |
#4 |
Mild termite damage to wall studs |
| Display Modes | |
| Sistering or shimming wall studs for drywall? | GSilversVeneer | Carpentry | 1 | 11-28-2010 01:41 AM |
| Does this look like termite damage? | Rachie7987 | Pest Control | 1 | 11-20-2010 09:01 AM |
| Running speaker wire from attic into exterior wall: Techniques? | homerb | Home Theater | 1 | 07-15-2010 02:55 PM |
| Advice on retaining wall replacement (pics inside) | eastie | Building & Construction | 0 | 04-05-2010 11:32 AM |
| Raising Doorway Height (load bearing?) | treefrog | Building & Construction | 6 | 02-25-2008 10:11 PM |
