MH Ready Patch Or Bondo.... - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-12-2012, 12:15 PM   #1
Rewards Points: 288
MH Ready Patch or Bondo....
I'm installing Soss hinges in standard 1 3/8 door.
The Hinges are monster...and in some area, the skin of the door is broken.
Help me pick my poison. MH Ready Patch or Bondo to just *skim* the missing area of skin where the hinge is at. Ready Patch is easier to sand right ?
I'm trying to recall but I remember using my Steel Files on Bondo..
mobiledynamics is offline   Reply With Quote
Old 07-12-2012, 04:11 PM   #2
Too Short? Cut it Again!
Do you need to repair structure at all and drill or rout this for new hinges?
MH Ready Patch is better to use with wood. I am not sure how Bondo became a popular wood patching material because it is a fiberglass type resin.
You might also consider a wood restoration epoxy like products from Abatron. You can color them and tool them with normal woodworking tools.
Old 07-12-2012, 04:43 PM   #3
Stairguy
Millertyme's Avatar
Rewards Points: 508
I find them both easy to sand. They both paint well too.
Millertyme is offline   Reply With Quote
Old 07-12-2012, 07:50 PM   #4
Rewards Points: 288
No structure at all. This hinge is much bigger than a Soss..when fitted inside the door, literally the skins is the only wood left in a 1 3/8 door...
So I'm just surface patching the area where *it was week and skin broke off* ....as the doors are paint grade
Old 07-12-2012, 08:16 PM   #5
Haverhill Trade 1965
I always seem to fall back on Durhams Rock Hard Water Putty. Just be quick, when it starts to set, it hardens faster than Bondo. It looks like what they fill knot holes in the veneer of plywood with.
Duckweather is offline   Reply With Quote
Spackle, MH Ready Patch, Drying In Can: What to Add? Lovegasoline Painting 1 06-11-2010 11:25 AM
EPDM Roof Patch antelope420 Roofing/Siding 1 05-11-2010 08:20 PM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 08:14 PM
Floor patch HomeDepot23 Flooring 2 07-24-2008 06:03 AM
squirrel damage to windows arnlieb Carpentry 9 11-12-2007 08:26 AM
