Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 12-01-2008, 08:38 PM   #1
metal or wood studs?
I want to build an attic room in a barn I live in, and must build out the existing rafters slightly to accommodate my insulation I plan to install. The obvious choice would be to use 2x4 lumber, but is it possible to use metal studs instead? They would be the lighter option but I'm not sure of the holding power of drywall screws into the metal studs. I have to add extra framing to also creat enough fastening points, as the rafters run about 24" apart. Each ceiling "side" is about 14' by 12', with the peak at about 11'. Do fine thread drywall screws into metal studs hold as well as coarse thread into wood? I'm open to any other ideas, as well.
pwise is offline   Reply With Quote
Old 12-01-2008, 11:49 PM   #2
fine thread into metal holds fine, they use them in comercial all the time. If you are worried about them not holding use a drywall adhesive along with the screw and you won't have to worry.
ponch37300 is offline   Reply With Quote
Old 12-02-2008, 08:57 AM   #3
Moderator
Termite's Avatar
Yup, fine thread drywall screws will hold just fine.
Old 12-02-2008, 09:27 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Realize that you also have ways of reducing insulation space requirements.
Examples: High-density Insulation has equal value of standard batts, while using less space.
Also: adding a ridgid foam board layer into the arrangement with HD batts, can create higher R-value, using less space.
- Build Well -
Old 12-04-2008, 05:47 PM   #5
Drywall contractor
Fine threads are actually intended for metal application and course thread for wood. The coarse threads tend to strip out in metal and fine thread often do not pull up well in wood. Adhesive isn't commonly used on metal studs, but certainly will help the situation and ease your mind if you have any doubt as to the screws holding....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 12-06-2008, 09:22 AM   #6
I surely haven't used metal studs enough to know any better but its hard for me to feel comfortable knowing that no matter how long the screw is, only a few threads are actually doing the holding when using metal studs. I have used them in the past and the wall hasn't fallen down, its just the concept of it for me.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 12-07-2008, 01:18 PM   #7
Drywall contractor
DUDE, I've hung A LOT of drywall on metal and never had a problem. Even 2 layers of 5/8" overhead (that's a lot of weight). I see your thinking, but the application works as designed........no worries. The inherent problems are the same as with wood. Water intrusion, 'ya got a problem and it could come down. Someone steps on the board from above in the attic, it's coming down. Not just under it's own weight though. Again, adhesive certainly won't hurt.
Old 01-21-2009, 12:08 PM   #8
Home Improvment Contactor
They got it nailed. Or screwed in this case. Fine thread and adhesive for metal. One other thing to remember is bugs don't eat metal.
Jack of most is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
9 foot span ok for metal studs as ceiling joists? Garasaki Carpentry 7 08-22-2008 10:12 AM
How difficult is it to learn to use metal studs? YerDugliness Building & Construction 7 08-18-2008 07:59 PM
finishing a basement- metal tracks & wood studs sweep the leg johnny Building & Construction 4 03-09-2007 04:05 PM
