Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 02-11-2013, 11:58 PM   #1
Metal or wood
Guys, I'm trying to decide which to use for my basement remodel. Metal or wood framing. Nothing especially heavy to be hung on the walls and no water issues.
Question two, if I do use wood framing is there a need for a double top plate on my framed walls? Thanks in advance for any help.
Mlorek is offline   Reply With Quote
Old 02-12-2013, 12:01 AM   #2
Metal or wood
I go with wood, pressure treated bottom plate, single plate on top and add fire blocking.
Old 02-12-2013, 06:20 AM   #3
Not so new
12penny's Avatar
Metal or wood
I use wood for walls also. Metal for soffit work.
12penny is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Best Non Toxic Metal For Pine and Birch Wood catsforever Carpentry 9 07-08-2012 01:46 PM
Wood furniture care/ Cleaning (I ?!#?!? up) bli182nk General Discussion 0 05-22-2010 02:31 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
