Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-08-2009, 01:43 PM   #1
Default metal wall studs
how easy are these to use and how do they compare price wise with wood also do you place 16" oc?
gary d is offline   Reply With Quote
Old 10-08-2009, 07:30 PM   #2
Civil Engineer
Metal studs are commonly used in commercial framing. I have seen them placed 24 inch OC, however they could be used 16 OC if there was a special need. The techniques for connecting them are completely different than for wood studs, however once you adjust they are great to work with, since they don't twist or bow like wood. You do need fittings when you run wires through them to keep the wire from getting damaged. Drywall attachment is also different than wood.
Old 10-08-2009, 07:56 PM   #3
Post
In residential applications you have to be careful, though, when planning to hang kitchen cabinets. Then, according to the "experts" wood is preferred. Also, there is a slight difference in price. Metal studs being lower priced. As far as the studs being spaced @ 24" O.C., the vast majority of partitions (in commercial applications) are still built to the regular standard of 16" O.C.! (no matter what)Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 10-08-2009, 08:09 PM   #4
concretemasonry's Avatar
For added rigidity and lower deflection, steel studs may also be at 12" O.C., but that totally kills (by 40% or so) the effective insulation on external walls with fiberglass insulation (thermal short-circuiting).
Dick
concretemasonry is offline   Reply With Quote
Old 10-12-2009, 10:48 AM   #5
Drywall contractor
The gauge of metal studs sold at home stores will require 16" spacing and you will need to add wood backing for anything that you are planning on attaching (other than pictures). As far as price, I wouldn't bet they're much, if any, cheaper these days with the price of metal skyrocketing. The HD web site shows an 8'x 3-5/8" metal stud selling for $3.58 (+ tax) and 10' track (needed top and bottom) is $3.98+. I think you can buy 2"x4"'s cheaper.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
More On This Topic
Hi, this is Jon on behalf of Expert Village. In this video clip we will be detecting metal studs. Before detecting metal studs, the first thing we need to do is change our selection to metal studs just to let our tool know that we do in fact want a metal... Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip we will be detecting wood studs. When detecting wood studs, the first thing we need to do is set our stud finder to wood to tell it that we are in fact going to be detecting wood studs... Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip I'll be answering the question, what does a laser line level stud finder tool do? The tool that we're going to focus is primarily on in this segment of video clips is a combination stud... Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip I'll be talking about tips for buying a stud finder. I have two different types of stud finder tools and each one has its own pros and cons. On our first tool our stud finder gives us the... Read More »
Hi this is Jon on behalf of Expert Village in this video clip we'll be formulating a design I came across this picture of easel and thought to myself this would be a great little project build however, rather than using the metal poles that they have I... Read More »
metal studs Talman48 Electrical 6 02-23-2009 08:15 PM
loose outlet boxes on metal studs windowguy Electrical 7 01-29-2009 02:12 PM
metal or wood studs? pwise Carpentry 7 01-21-2009 01:08 PM
insulating when gap b/ween studs and brick wall amakarevic Building & Construction 0 06-16-2008 02:05 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 11:47 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
