Metal Studs - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-12-2011, 10:16 AM   #1
Metal studs
How do you install wall cabinets to metal studs? Are they strong enough to hold them without adding some sort of support?
gkschet is offline   Reply With Quote
Old 02-12-2011, 03:23 PM   #2
Rewards Points: 5,336
Are these structural metal studs or the light guage metal variety used in basements and partition walls?
Ron
Old 02-12-2011, 03:38 PM   #3
I'm not sure. They were used in the basement on the exterior and interior walls. They are now covered with drywall, but if I remember correctly, they seem to be somewhat flexible.
Old 02-12-2011, 04:24 PM   #4
I'd reinforce the wall before I hung any cabinets.
I'd provide blocking where the cabinets were being screwed to the wall, top and bottom. And replace the sheetrock behind the cabinets with 1/2" plywood, screwed into the blocking and intermediate bridging.
The plywood not be visable past the cabinets.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
gkschet (02-13-2011)
Old 02-12-2011, 04:42 PM   #5
Ron
This ^
mrgins is offline   Reply With Quote
The Following User Says Thank You to mrgins For This Useful Post:
How to add blocking w/ steel or metal studs bergerdude Building & Construction 12 04-30-2013 10:59 AM
metal studs, best screws to use for attaching cabinets? cbushrun Building & Construction 6 03-29-2010 07:10 PM
Metal framing for basement Drop Cieling? joliet_man@yahoo.com Carpentry 3 10-22-2008 02:16 PM
insulating metal studs - help maintenance Building & Construction 2 08-05-2005 05:31 PM
Penetrating Metal Studs gbarron1 Building & Construction 12 03-19-2005 12:13 AM
