Metal Studs - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-23-2011, 05:41 PM   #1
Metal studs
How do I nail moulding to metal studs? Thx
Jpscherer is offline   Reply With Quote
Old 09-23-2011, 05:42 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You don't.
Old 09-23-2011, 05:56 PM   #3
Framing Contractor
Rewards Points: 112
Trim screws.
Google is your friend!
sixeightten is offline   Reply With Quote
Old 09-23-2011, 07:14 PM   #4
Rewards Points: 5,336
I'm sure this is a little late in the project, but here goes.
When using metal studs, I install 1/2" ply at the base to nail the trim into. I also add wood 2x4's around the doors and windows so I can nail the trim on.
Trim screws will work on painted moldings. Not so well on stained.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
jschaben (09-23-2011)
How to add blocking w/ steel or metal studs bergerdude Building & Construction 12 04-30-2013 10:59 AM
Wood or Steel wall studs? dredogol Building & Construction 2 07-10-2011 08:31 AM
metal studs, best screws to use for attaching cabinets? cbushrun Building & Construction 6 03-29-2010 07:10 PM
insulating metal studs - help maintenance Building & Construction 2 08-05-2005 05:31 PM
Penetrating Metal Studs gbarron1 Building & Construction 12 03-19-2005 12:13 AM
