Metal Strap On Wood Framing. Can I Cut It? - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-06-2011, 08:14 PM   #1
Metal strap on wood framing. Can I cut it?
I'm trying to install a dog door. When I opened up the wall where I want/have to install it, there was a metal strip across the area. It looks like a hurricane strap. But I don't want to cut it if it's important. I live in Arizona, so hurricanes and tornadoes are not a big concern.
Bottom line, can I cut this? (See picture here https://picasaweb.google.com/103916711808214386689/August62011?authuser=0&feat=directlink)
monteconde is offline   Reply With Quote
Old 08-06-2011, 08:25 PM   #2
Licensed Builder
Handyservices's Avatar
Bottom line, can I cut this? (See picture here https://picasaweb.google.com/1039167...eat=directlink)
Do not cut it. It is probably for protecting wiring or plumbing in the wall. They put those metal strips in there so others won't mistakingly put a nail in a pipe or electrical wire--or CUT THEM. Simply patch the hole back up and place the doggy door a few feet over.
Handyservices is offline   Reply With Quote
Old 08-06-2011, 08:59 PM   #3
Registered User
Rewards Points: 526
As said, NO- don't cut it. It is a required seismic strap for your Zone "C" or "D" you live in- keeps your house upright: http://publicecodes.citation.com/ico...001_par004.htm
Gary
Old 08-06-2011, 08:59 PM   #4
Rewards Points: 5,336
Move the dog door to another location.
Ron
B. Franklin 1759
Wood Fence with metal post BDestroyer8418 Building & Construction 8 09-24-2011 09:49 PM
Pros and cons to wood vs steel I beam framing buildings viper Building & Construction 1 05-22-2011 05:17 PM
Metal Stud framing ? ct73 Remodeling 3 02-06-2010 11:15 AM
Metal Stud Framing in Basement toolman327 Building & Construction 2 01-01-2009 06:52 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
