Metal Framing For Basement Drop Cieling? - Carpentry - DIY Chatroom Home Improvement Forum
Closed Thread
Old 10-18-2008, 02:35 PM   #1
Carpenter and DIYer
Send a message via Yahoo to joliet_man@yahoo.com
Exclamation
Metal framing for basement Drop Cieling?
I just got a job to frame out a basement in metal studs. I am young never used metal studs I have always done custom housing all wood frame. I have done many many basements and never done metal. So basically I am asking for a quick crash course, inmetal studs for the basement. I have a basic idea. just looking for quick tips and major concepts. What do I use for the bottom plate for moisture. Not a flood worry, just basic moisture you know do I use green plate any moisture barrier anything. Oh yea i am thinking of the trim should i use a wood bottom plate under the track for trim purposes so i have that nailer. Also he wants a drop cieling how do i do that basically out of metal studs or do i use wood or just a just fir it down with 2 by 2 or what I am just gonna box in the steel is that possible in steel well i am sure it is but how? Please help me all help is greatly appreciated.
Young and eager Carpenter learning all aspects of trade.
joliet_man@yahoo.com is offline
Old 10-18-2008, 03:53 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
Sorry ! This site is mainly geared for the DIY homeowner. Try Contractor Talk. There you could Talk amongst other eager contractors. Good Luck BOB.
buletbob is offline
Old 10-22-2008, 01:09 PM   #3
Metal framing
Hi I read your posting. If you go to www.rd.com there is a whole lot of information. Just type in metal/steel framing it walks you through the whole process
Hope this helps
Good luck
Mirimaggy is offline
Old 10-22-2008, 01:16 PM   #4
Registered User
Termite's Avatar
Agreed. Contractortalk.com is a much better resource for contractors.
Termite is offline
Closed Thread
metal or wood soffit framing WTDoc Carpentry 1 03-31-2008 09:06 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
Framing around 4" metal pole xlr8tn Building & Construction 4 01-16-2008 07:39 PM
metal framing davidfenton Building & Construction 8 07-07-2006 06:20 AM
