Hello,
I'm in the process of building a fence and I am looking for a material, that's like this...
http://st.houzz.com/simgs/5ef11b9901159015_4-7644/contemporary-fencing.jpg
Ideally they would be totally flat 4" wide pieces (6' to 8') in length. I would screw them into vertical fence posts.
The closest thing I've found at Home Depot has been galvanized steel sheets which are flat but only come in square dimensions (1' by 2', 2' x 2', etc) I also found rolls of steel with a satisfactory width, but I'm concerned about unrolling, applying, it and it looking like paper, and not a flat piece of clean metal.
Some considerations regarding the metal, it will be outdoors, directly attached to treated wood, possibly soil (some at the bottom), I live in southern CA, so it's not too wet or cold.
Any other materials, you could recommend that would accomplish a similar look? I would prefer not to use a different kind of wood (to keep consistent with a modern look)
Thanks for all your help!
