Metal Door Casings - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-28-2015, 09:53 AM   #1
Rewards Points: 2
Metal Door Casings
First off, I'm really excited to have become a member here. Most of my google searches typically bring me here so I finally decided to sign up now that my girlfriend and I are in the process of fully renovating our 1960, 1K sqft ranch style home. I'm very fortunate in that I'm a firefighter so I have a lot of time off to get stuff done so it's been moving along nicely for the most part.
We are currently in the process of laying down laminate flooring and when it came time to undercut the jambs/casing, I noticed the casings were metal. I used a dewalt oscillating tool to under cut the casing/jambs however, the casings are flush with the plaster walls and are basically a quarter round/bull nose into the jamb.
I need a way to hide the small gap where the expansion gap juts out from under the door casing. I'm going to be putting down baseboards but that will still leave an ever so small gap where the casing curves. Is there a way to tie in a baseboard with the rounded casing? I've read about making four 22.5 degree cuts but all of the baseboards I've seen would be too thick and would interfere with the door opening/closing.
I'm currently on duty but I'll upload pictures when I get off work tomorrow morning as I'm sure that will help if anyone is having trouble grasping what I'm describing.
Dr_Cornwallis is offline   Reply With Quote
Old 12-28-2015, 11:08 PM   #2
Rewards Points: 1,036
Can you get some pictures up?
Mingledtrash is offline   Reply With Quote
Old 12-31-2015, 06:08 AM   #3
Rewards Points: 2
Sorry for the delay, I'm working on getting some pics. Been a busy few days!
Old 12-31-2015, 06:09 AM   #4
Rewards Points: 2
Old 12-31-2015, 07:08 AM   #5
GrayHair's Avatar
Rewards Points: 938
I remember those, although I don't remember them in residential. Once you've determined how much needs to be removed, you can use a die grinder with a reinforced cut-off disc. I strongly recommend a full face shield.
Any mention of codes is based on NFPA 70 and/or 72, as applicable, because they are the most widely adopted codes in the US. Local amendments may modify the code adopted in your area, so consult your local codes official.
GrayHair is offline   Reply With Quote
Old 12-31-2015, 10:08 AM   #6
Rewards Points: 2
Metal Door Casings
So you would cut them farther up, as in just above the baseboards and then caulk the gap?
Old 01-01-2016, 11:04 PM   #7
Rewards Points: 2
Thought I would give this thread a little bump for some more ideas.
Old 01-02-2016, 12:54 PM   #8
GrayHair's Avatar
Rewards Points: 938
Personally liking a tight fit (no caulk), I'd take a scrap of flooring, stick a couple of layers of masking tape on it and make a trial cut. When I can slip flooring under the casing without gouging it, I'd call it good. Add layers of masking tape as/if needed; you cut more casing off, but you'd be hard pressed to put it back. And yes, I'm often anal retentive.
Old 01-03-2016, 03:23 PM   #9
AHH, SPANS!!!
Rewards Points: 1,166
your oscillator with a metal blade may cut it or go with a grinder with a metal cut off wheel and cut a small 1/8" above the flooring thickness or even a tight cut if you can manage it. way better to have a tight cut than to caulk it later....
hand drive is offline   Reply With Quote
Replacing latch on metal framed garden gate tinan General DIY Discussions 2 09-06-2015 03:26 PM
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 02:33 PM
Replacing metal box caused issues rivers001 Electrical 28 03-07-2011 01:21 AM
How to drill through metal in headers Docfxit General DIY Discussions 5 07-05-2009 11:31 PM
I'm New & Need Help With Metal Shower Trim dawn312 General DIY Discussions 2 06-06-2009 02:43 PM
