Measuring Trim For Mitered Baseboard Installation - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-27-2009, 11:42 PM   #1
Measuring trim for mitered baseboard installation
I'm looking to install baseboard trim in my dining room. I have an electric compound miter saw and know how to use it, but my problem comes when I measure the walls to make the appropriate cuts.
For "outside corners": If I measure the wall exactly, cut the trim to that length, then make the mitered cuts on the ends, won't that screw up the length? Do I need to add 1/2 inch to each end when cutting the trim to length to make up for the mitered corners?
This problem doesn't occur when cutting trim for inside corners because you're cutting excess off of the trim so it can fit into the corner, but in an outside corner you need the ends to stick out further than the measured length of the wall.
Maybe I'm just not visualizing this correctly -- spatial intelligence was never my strong suit. If anyone can help, I'd appreciate it!
abbyqueue is offline   Reply With Quote
Old 07-27-2009, 11:55 PM   #2
The first step is to take a rough measurement of the wall, cut you piece about 6 inches too long, then put your measuring tape aside.
With your rough cut piece, cut one side with the cut you want then walk over to your wall and mark where the other cut needs to be made.
It usually is easier to make the inside cut first then mark an outside cut.
For two inside corners its a bit tougher but you'll get the hang of it.
derf36 is offline   Reply With Quote
Old 07-28-2009, 12:04 AM   #3
Registered User
Termite's Avatar
Good advice there. Put the tape measure down and "sneak up on the measurement" a little at a time. Helps to have the saw close.
Your outside corners should be mitered but inside corners should never be mitered. They should be coped. Mitered inside corners just scream "an amateur did this!!!" It isn't hard and it can be done with a $12 coping saw and a little practice. Do a search on youtube for coping baseboard.
Old 07-28-2009, 12:54 PM   #4
Registered User
Rewards Points: 526
http://books.google.com/books?ei=8h0...G=Search+Books
Click on the "limited preview" books. Be safe, G
Installing baseboard trim on curved wall billyg Carpentry 8 02-06-2009 08:25 AM
Baseboard trim height from floor billyg Carpentry 6 01-20-2009 10:08 PM
Bland Baseboard Trim tigerbalm2424 General DIY Discussions 17 06-19-2008 11:19 AM
baseboard trim gaps on stairs beppygirl General DIY Discussions 8 02-24-2008 01:31 PM
attaching baseboard trim DIY4EVER Carpentry 11 11-28-2007 12:31 PM
