Measuring Angles Laminate Flooring - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-26-2010, 08:49 PM   #1
measuring angles laminate flooring
how do you measure angles?
felicity7 is offline   Reply With Quote
Old 12-26-2010, 09:46 PM   #2
Rewards Points: 5,336
Protractor.
Bevel guage.
What are you trying to specifically do?
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
felicity7 (12-26-2010)
Old 12-26-2010, 10:12 PM   #3
measuring angles
I'm trying to lay the last few rows. The room comes to a diagonal near the door.
I was trying to find a video showing how to measure, mark and cut.
Old 12-28-2010, 01:21 PM   #4
Bevel guage. You can pick one up at hardware or lumber stores. Cost under $10.00.
Ron
felicity7 (12-28-2010)
Old 12-28-2010, 05:49 PM   #5
laminate measuring
Thanks Ron!!!
Old 12-28-2010, 05:49 PM   #6
laminate measuring
Thanks Ron
Old 01-23-2011, 10:59 PM   #7
Rewards Points: 212
just measure the long to square and the short to square the angle doesn't matter
bluebird5 is offline   Reply With Quote
The Following User Says Thank You to bluebird5 For This Useful Post:
felicity7 (01-26-2011)
Old 01-24-2011, 03:14 PM   #8
As you allready have much of the flooring down, butt a piece of flooring up to the wall parallel to the installed flooring. Take another piece of flooring or wider board and place it against the angled wall. Scribe that angle onto the flooring and then set you miter saw to the scribed line.
You can do the same thing with a bevel gage and add it to your tool collection.
masterofall is offline   Reply With Quote
The Following User Says Thank You to masterofall For This Useful Post:
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 07:37 PM
measuring angles - flooring felicity7 Flooring 3 12-29-2010 07:33 AM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 03:55 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 02:20 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 11:34 AM
