Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 06-07-2008, 04:08 AM   #1
measure size screen door spline
I'm about to replace my patio door screen using fiberglass screen,
I bought a three sizes in one package.
Is there a proper way to measure the groove to know what is the right size rubber spline to use.
deck hand
deck hand is offline   Reply With Quote
Old 06-09-2008, 08:05 AM   #2
gravity always wins
Why not re-use the original spline? Or measure it. It should be the right size.
Old 06-09-2008, 08:59 AM   #3
Moderator
Termite's Avatar
The spline should fit into the groove under pressure excerted by a spline roller. You definately need this tool to properly do the job. The spline should be tight enough that you can't get it in there with fingers alone.
Size of whole house fan needed Doug Crf General Discussion 20 02-26-2011 12:29 AM
How to measure for new pre-hung interior doors jencampo Carpentry 3 03-25-2008 01:49 AM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 06:00 PM
How to measure windows for new construction? pastrami Remodeling 1 04-26-2007 08:36 PM
