-   -   measure size screen door spline (http://www.diychatroom.com/f14/measure-size-screen-door-spline-21937/)
deck hand 06-07-2008 03:08 AM
I'm about to replace my patio door screen using fiberglass screen,
I bought a three sizes in one package.
Is there a proper way to measure the groove to know what is the right size rubber spline to use.
deck hand
Maintenance 6 06-09-2008 07:05 AM
Why not re-use the original spline? Or measure it. It should be the right size.
Termite 06-09-2008 07:59 AM
The spline should fit into the groove under pressure excerted by a spline roller. You definately need this tool to properly do the job. The spline should be tight enough that you can't get it in there with fingers alone.
