Maximum Hole In Floor Joist - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-11-2008, 07:22 PM   #1
Risch
Maximum hole in floor joist
Hi. I need to re-route a 6" vent run through a 10" joist, and continue the run to an outside vent. I understand it can be done. I need to know what size hole through the joist would be best to maintain joist strength integrity' i.e.: a 6" hole with two 90 degree vent turns, or two 10"x3"x6" register boots? I appreciate any help and suggestions
Risch
Risch is offline   Reply With Quote
Old 02-11-2008, 08:40 PM   #2
Rewards Points: 528
A 6 inch hole in a 10 joist is too big. Don't do it. I believe the maximum allowed size is near 2-1/2 inch's. A carpenter should be along soon who will give the exact size on a 10 inch joist and other details.
You will have to run the duct under the joists.
I just found this on a search, go to:
http://tileyourworld.com/constructio...oringGuide.pdf
Its everthing you need to know on boring and notching joists.
rjordan392 is offline   Reply With Quote
Old 02-11-2008, 09:18 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You'll have to come up with another route for that vent.
The previous link does a good job at explaining the "concept" of putting holes in joist, and maximum allowed bore size.
- Build Well -
Old 02-12-2008, 02:57 PM   #4
Framing Contractor
Risch
Who told you that you can cut a 6" hole in a 2x10?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 02-12-2008, 03:51 PM   #5
J Calvin Construction
jcalvin's Avatar
Rewards Points: 150
You can drill holes in joist no closer than 2 1/2 from the outside edge of the joist, but, the hole cannot be any larger than 1/3 the floor joist...3 1/3 inches at least in NC.
jcalvin is offline   Reply With Quote
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 26 11-13-2011 09:35 AM
Fixing 11" Hole in Concrete Foundation robertr4836 Building & Construction 6 02-04-2008 08:08 AM
Tool to deepen deadbolt hole? darsunt Carpentry 5 07-18-2007 10:45 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
I hope I don't have to tear down the ceiling brds16 Carpentry 9 04-30-2005 10:16 AM
