-   -   math for checking for 90 degrees in a corner (http://www.diychatroom.com/f14/math-checking-90-degrees-corner-5049/)
coderedcraze 11-27-2006 12:12 PM
Can someone tell me the math you use to check for square of a corner, the math makes a triangle with a 90 degree angle which would be the corner.
jproffer 11-27-2006 12:37 PM
3-4-5
Measure out 3 feet (or 3 anything...inches, feet...but the longer the better) on one side and mark it. Measure out 4 feet(or units) on the other side and mark. If the corner is 90 degrees, the measurement between marks will be exactly 5 feet (units).
If it's not 5 feet and you are looking for the exact angle, it gets a little more complicated (trig), but if that happens come back and we'll step you thru it.
yummy mummy 11-27-2006 12:38 PM
Do you mean the 3, 4, 5 rule?
You measure 3 feet across one wall, and make a mark, then measure 4 feet across the adjacent wall, and make a mark, and the measurement between those points is 5 feet.
Is this what you are looking for?
Fux39 11-27-2006 06:16 PM
Yes thats what he means.... the rule is (AxA) + (BxB) = (CxC)... Which in the end with the 3 4 5 rule... It would equal out to... 9 + 16 = 25... Do you follow???
joasis 11-27-2006 06:58 PM
The basic carpenter's method is the 3-4-5 rule, or multiples of it...makes things simple, We use it for checking forms when seting up next to buildings if we don't shoot with a transit.....some guys build a large square for this...lots of old home improvement books show it.
AtlanticWBConst. 11-27-2006 07:17 PM
You're getting good :thumbsup: .....
yummy mummy 11-27-2006 07:48 PM
atlantic
I'm real good! :wink:
Bonus 11-27-2006 08:37 PM
There's a bunch of them, 5:12:13 works well for long skinny buildings.:laughing:
vapros 11-30-2006 07:50 PM
Alternatively . . .
Pythagoras is smiling today. Maybe this is belaboring the obvious, but I don't know of anything squarer than the corner of a sheet of plywood.
Correct me if I'm wrong, you pros out there, but isn't that square enough for all building projects?
redline 12-01-2006 07:40 AM
How about a carpenters square?
:thumbup:
joasis 12-01-2006 10:40 AM
Most of the DIY'ers would be surprised at how out of square most construction projects can end up...especially by us experienced guys. I was taught by a craftsman, and it is a point of pride for me that we build true and square, but I can't count the number of homes and commercial buildings that are not just a little, but way out......one of the nationally known home builders...the one that builds a house for you on land you own with nothing down, to 90% completion, and let you finish the rest to "save" money, is the worst overall...I have seen rooms...10 x 12, out 4 inches, no joke, and roofs that are a foot out, not to mention floors and doors out of level and plumb....but what would you expect from a crew that flies in and literally slaps it up in a week with #3 lumber, and wants to move on to the next one. A mobile home that has been moved a few times is more square.
yummy mummy 12-01-2006 01:21 PM
I had my home built 3 yrs ago, and now that I know how to check to see if the rooms are square, there isn't even one room that is perfectly square.
So I believe what you say about even the so called "pros" can't be perfect.
So, I am really happy that the basement that I am renovating, my first use of the 3,4,5 rule, and I am out by 1/4 inch.
I say that is pretty good. Mind you it took me 2 months to frame 2 walls.
joasis 12-01-2006 02:15 PM
Just 2 months? sounds like you are a pro...that is the way my crews do it if I am not cracking the whip.
yummy mummy 12-01-2006 03:10 PM
If you want to continue making money, you better crack that whip. :laughing:
yummy mummy 12-01-2006 03:16 PM
joasis
When I was building my house, and I asked the contractor why was he taking so long and why all of a sudden there would be 2 weeks where no one was on the job site.
His reply was that he cannot make a living just on my house alone.
This was my first time building.
If I had to do it again, (and overall it was a good experience), I would research all aspects of building from footings to fixtures, and if I had the time, I would contract it out myself, and I would be on the subs butt 24/7. :laughing:
And I bet I would end up with a much better built house.
Joasis, as a general contractor yourself, would do you think about this?
