Matching Roof Angles For A Porch - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-06-2010, 09:09 PM   #1
Smile
matching roof angles for a porch
We have a mobile home with a high peak in the front. Any suggestions on how to build a proch to match the peak?
vidandkel is offline   Reply With Quote
Old 04-07-2010, 06:22 AM   #2
That is often not possible or practical due to headroom requirements. Porches often have angles different from the roofline.
Old 04-07-2010, 10:59 AM   #3
Agreed, the porch roof will start to hang down too low. I.E. if you have a 9/12 pitch on the house, and the headroom from your porch to the end of the roof tail is 10'(extremely high) and your porch extends 4' from the house, you'll have a 3' drop from where the roof was to where it would be at the end of the porch, which would be 7'. Most houses are at 8' though, then you'd have to duck to make it out from under the roof over your porch. If you don't want to have 2 different angles, you can overframe your roof right now, and put new rafters in all the way to the peak, that will extend out over the porch, and can end up at the same height as the rest of the roof. This is obviously more expensive, but probably looks better than any other method.
lanemiller is offline   Reply With Quote
Where porch roof meets wood siding Trish99 Roofing/Siding 14 07-16-2009 08:31 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Porch roof tie in question dabensys Carpentry 6 08-11-2008 02:46 PM
How to combine two different angles of a porch roof at the corner northstarws Building & Construction 6 08-10-2008 10:36 AM
new porch roof to existing home jscholl411 Roofing/Siding 6 10-11-2007 11:24 PM
