Matching Baseboard To Tile - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-08-2011, 07:41 PM   #1
Rewards Points: 79
Matching baseboard to tile
I need to match a baseboard end where it butts up against a caulked bull-nose tile.
The baseboard is 1/2" thick & the bull-nose tile piece is rounded down to about 1/4", maybe a little less, and is caulked (not grouted).
The tile is at the bottom of a tub, with the bull-nose away from the tub where it meets the baseboard that runs away from the tub.
I know I need to somehow trim the baseboard down to the tile and its caulk, but am not sure how to do that.
Any suggestions?
Thanks!
janralix is offline   Reply With Quote
Old 12-08-2011, 08:02 PM   #2
Old School
Willie T's Avatar
I just do a 90 degree return.
Willie T
Old 12-10-2011, 08:33 PM   #3
Put the baseboard up against the tile and use a compass to scribe the tile's profile on it. Then use a coping saw to cut it out. I'd clean the caulk off the tile before scribing and then re-caulk after
mrgins is offline   Reply With Quote
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 08:03 PM
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
matching up 1/2" hardwood floor to 1" tall tile cmlcsu Flooring 3 10-20-2009 08:56 PM
basement issues - tile, mastic, moisture pfisch Flooring 6 12-01-2008 01:35 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
