Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-28-2011, 10:28 PM   #1
Masonite type stucco siding
The front of our home has a Masonite type stucco board on it with cedar trim (tutor like look). The bottom of some of the Masonite- type boards are showing some rot. It looks like the paint is bubbling in certain areas but one has a chunk missing.
We had a quote to replace the one board and cedar trim ( and paint it for $1400) and replace the whole 2 story boards and cedar trim , an paint it for $3200). Is it look to replace it all at once or wait?
The other temp option I looked up was using some paste type hardening filler to fill a cut away section of the Masonite and paint. This might be a 3-4 temp fix.
Thoughts?
Cmeller is offline   Reply With Quote
Old 03-28-2011, 10:55 PM   #2
Tom Struble's Avatar
thing is you don't want it to get bad enough to start being a problem with your houses sheathing,any moisture damage should be removed and the source of the problem should be rectified and repaired,not simply covered up
Tom Struble is offline   Reply With Quote
Old 03-28-2011, 11:07 PM   #3
Thanks. Sorry for typos on my phone. Do you think a cement board is the way to go?
Old 03-28-2011, 11:15 PM   #4
yes probably,but the challenge is to flash and caulk it properly so no water is allowed to get between panel and trim,or if it does get in it can drain freely
hardie plank siding bob fortier Carpentry 4 05-31-2010 08:01 AM
ledger stones on stucco wall, but wall is bowed rrauenza Building & Construction 7 05-18-2010 06:38 PM
Hardie over Masonite siding??? canyonbc Remodeling 2 01-27-2010 09:57 AM
Siding, I have wooden, and I want Aluminum or stucco TheSiege Remodeling 9 09-10-2007 01:45 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
