Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-19-2011, 10:25 AM   #1
Masonite solid core door slabs too narrow?
I've just removed two swing doors and installed pocket doors in their place. I changed out the original solid pine six panel swing doors (circa 1977) with Masonite roman arch solid core doors.
The original door slabs replaced measured 2.0 (24 inch) and 2.8 (32 inch) exactly. The Masonite door slabs measured 23 3/4 and 31 5/8. Is that normal for replacement slabs to not be the actual stated size?
It didn't cause too much of a problem since the new doors fit the pocket door opening without gap. I'm thinking of replacing other swing door slabs in the original frame, but that won't work if the new door slabs are significantly narrower.
Any advice or information is appreciated.
PS: I new to the forum, but got very useful information on header spans from DIY Chatroom when I started my pocket door project. Thanks for sharing!
VR,
Alan
Airnail is offline   Reply With Quote
Old 09-20-2011, 03:01 PM   #2
Interesting response from Masonite. I guess I'll use Reliabuilt door slabs from L**** since they are exact sizes.
To: ******@yahoo.com
Sent: Monday, September 19, 2011 4:04 PM
Subject: RE: Masonite Got a Question Form - Sep, 19 2011
Hello Felix,
None of our doors are true to size all of them are under cut.. If you
have any other questions or concerns feel free to contact us... Thanks!
Old 09-20-2011, 05:02 PM   #3
Hello Felix,
Lowes is the devil.
Casual use of the asterisk is a 15 yard penalty.
Ron
B. Franklin 1759
Old 09-22-2011, 07:18 PM   #4
Originally Posted by Ron6519 View Post
Lowes is the devil.
Ain't that the truth!
mrgins is offline   Reply With Quote
Old 09-22-2011, 07:34 PM   #5
There is no truth.
Ron
B. Franklin 1759
Old 09-22-2011, 07:35 PM   #6
and if there was, you couldn't handle it!
Old 09-22-2011, 08:00 PM   #7
Ther is no truth.
Ron
B. Franklin 1759
Sound insulation: Changing interior hollow core door to solid core, or exterior door? aminus21 Building & Construction 1 03-10-2011 01:43 AM
Need soundproof: Changing interior hollow core door to solid core, or exterior door? aminus21 Remodeling 4 03-08-2011 03:19 PM
hollow or solid core door for pocket door RobertN Building & Construction 2 08-31-2010 11:53 PM
Turning an existing solid core interior door into a french one? laurajeany Carpentry 13 11-29-2009 07:41 AM
Attaching Floor Joist To Solid Core CMU basement wall jrepp Building & Construction 5 04-23-2009 03:57 PM
