Marry Durock To Drywall - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-27-2008, 01:59 AM   #1
Pro Painter
Marry durock to drywall
I'm a fairly regular contributor to the painting forum and a member of CT and Painttalk. Hello my brothers of another trade.
I have to do a job where there was a leak inside the wetwall of a shower. The leak is fixed, the bottom 1 foot of drywall was removed and the HO wants me to durock that area, since it was the only part damaged.
The existing rock is green or blueboard with 4x4 ceramic tiles. I haven't done a detailed inspection, but at this point, the rest of the walls look fine. I'll check it further before doing any work.
Is this Ok to do? If so, any pointers?
Joewho
joewho is offline   Reply With Quote
Old 04-27-2008, 11:31 AM   #2
I'm not sure there's much you can do except mud and tape. I had a similar situation in my tiled shower. After replacing the pan we used durock up 3' or what ever the width of one is. The rest of the shower was excellent and did no need anything done. Made as tight as possible then mud, tape with the stuff that made for it and muded again. Applied adhesive and tiled. That's it.
ps. the only thing that may happen is if the dryall and durock are different thicknesses.
raam is offline   Reply With Quote
Old 04-27-2008, 02:38 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Yes, it is ok to install the durock and then to tape and coat over as regular sheetrock.
- Build Well -
Old 04-29-2008, 04:35 AM   #4
Pro Painter
Thanks AWC!
Already installed it with waterproof screws.
Ram, the drywall and cement board are differnt thickness.
HO already had 1/4" cement board with 1/2" drywall. I just cut strips of durock and screwed them to the studs to level it.
The walls are in good shape and there was no mold. I was just asked to install the rock. No fiberglass tape, mud, butter or anything else. The HO is doing all that.
Cost to Drywall hang/finish...please read, good explanation Firehawk734 Remodeling 64 12-12-2014 05:15 PM
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 01:05 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
Bathroom - Durock murphy54 General DIY Discussions 12 02-10-2008 10:12 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
