Mantle At Brick - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-06-2013, 10:09 AM   #1
mantle at brick
Looking for a good way to install a wood mantle at this brick fireplace. Are there some simple designs out there? How would you anchor it securely?
bpk3 is offline   Reply With Quote
Old 10-06-2013, 10:40 AM   #2
kwikfishron's Avatar
Rewards Points: 832
The simplest way would be to buy a mantle kit, there are many out there..google it. The manufacture will likely include the mounting instructions.
kwikfishron is online now   Reply With Quote
Old 10-06-2013, 10:46 AM   #3
Rewards Points: 317
Are you making the mantle yourself, or is it already
made and you're asking how to attach it?
Two Knots is offline   Reply With Quote
Old 10-06-2013, 11:58 AM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 596
Build your mantel where it will slip over a 2X4 that would be mounted on the brick wall. Glue and screw or lag the 2X4 to the brick wall, slip the mantel over the 2X4, screw or nail to the 2X4 from the top back. If you plan on legs on the mantel it will help support it also. I use to build some of them in place, and some off site but that is the way we secured to brick.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Brick Jack Arch - options for cutting brick PAbuilder Concrete, Stone & Masonry 4 01-30-2013 07:00 PM
Cleaning & Sealing Red Brick JasonCA Concrete, Stone & Masonry 3 01-23-2013 11:56 AM
Brick veneer is 4 rows below grade- redo or leave? cbrc5eric Building & Construction 11 12-27-2011 08:09 PM
Started Exposed Brick Wall, Studs within brick, should I stop? perry167 Building & Construction 4 01-05-2011 09:41 AM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 08:50 AM
