-   -   Making your own 4 inch tongue and grove (http://www.diychatroom.com/f14/making-your-own-4-inch-tongue-grove-178366/)
mj12 04-29-2013 11:36 AM
I would like to put a 13 foot wall across my basement. I do not want to use drywall. I like the look of vertical hung 4 inch tongue and grove boards with a stain. I have been pricing 4 inch t$ g boards and am not happy with the price for pine. I do not like the look of 8 or 10 inch. What is the most budget friendly way to make a board to cover the wall? I have a router table, can I make my own? Any ideas on a wood wall covering?
kwikfishron 04-29-2013 11:47 AM
199 Attachment(s)
It doesn't get much cheaper than pine. Most of the pine t&g I see is either 3 or 5 exposure. Not sure you would really save much making your own unless you already have the wood.
I paid about $140 for my t&g router bit set and that was about ten years ago.
ddawg16 04-29-2013 12:05 PM
Have you priced out decent pine? 3/4" clear pine will most likely cost you more than the T&G....then toss in your labor....it becomes a no brainer....
Have you called a lumber yard to get their prices?
RWolff 04-29-2013 12:33 PM
You can make T&G without much trouble, though you do lose about 1/2 of the board width to do it so you'd keep in mind that 12' worth of raw board width might wind up being like 11' which means you'd have to factor in the cost of buying say 3 or 4 more boards to get the width back you lost.
A router works fine, but you'd have to go and spend the money for a pair of router bits and either way you go will cost you more than the ready made boards, so unless you plan to do a lot or more projects it would be silly to spend the money on cutters or router bits for a small one time project.
You can rough it on a table saw if you have one, or the router table would work too- cutting a 1/4" slot out IF the boards are nice and straight, if they have warps etc it's a real pain. Then you'd want to bevel the visible edge on the board with the tongue after cutting that.
Frankly I think it would a big pain doing it this way, and the success depends a lot on how flat the boards are.
A poor man's method that might be easier but not nearly as nice- just make a table saw cut on the board laid flat, make a 1/2" deep x 1/8" wide cut on both facing edges of the boards, when laid up edge to edge there will be a 1/4" wide gap line but wood touching in the back, you could put a small bevel if you have a bit, not pretty but for the garage it's probably good enough.
ddawg16 04-29-2013 02:14 PM
I'm getting ready to buy a bunch of T&G for the overhang of my addition. I was at Home Depot last night....$0.72/ft for 5" planks.
I called my local lumber yard.....$0.51/ft for spruce.
Not even close to worth the time to try and do it myself.....
jagans 04-29-2013 02:52 PM
I would not use spruce. I warps and twists if you look at it funny. I think the OP needs T&G Knotty Pine.
mj12 04-29-2013 03:58 PM
I will just have to keep looking until I can find a deal on some 4 inch t&g. I have not called the local lumber yard yet. I want to mount the boards to a 2x4 16 oc framed wall. How should the wall be framed, I figure I should block the middle of the wall with 2x6. I want to nail a straight pattern, even if it will not show the nail heads.
Maintenance 6 05-02-2013 01:17 PM
You'll either need several rows of blocking between the studs or furring strips nailed across. Spruce T&G might be OK if it's well nailed, but would be paint grade only. Probably lots of tear outs. Spruce is almost never used where it is exposed.
