Making A Wood Counter - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-29-2011, 08:09 AM   #1
Making a wood counter
I am trying to make a wooden counter top for a friend. It will be approx. 3' x 4'. She wants it made for 3/4" Oak. The material she has supplied is 6" wide boards. I ripped them in half and made 3" wide boards. I have planed and joined all the faces. I am ready to glue the wood together and am wondering if I should be using biscuit? If so how many and what size?
I am not a wood worker and am just doing what I think is correct. So if there is a better way to join them please advise.
screwy is offline   Reply With Quote
Old 04-29-2011, 06:41 PM   #2
is this for a kitchen? I wouldnt think oak would be the best choice for a kitchen counter.
the biscuits help align the pieces, they used to just glue and clamp before they had biscuits.
Old 04-29-2011, 10:09 PM   #3
I agree. Since I am doing this as a favour I am not too concerned with the application but I am more interested in the process of joining multiple pieces of wood to produce a larger slab.
Basicly, would you just glue the pieces of wood together or use biscuits or another method?
Old 04-29-2011, 10:31 PM   #4
Registered User
Termite's Avatar
Biscuits aid in alignment but will not add much strength to an edge-glued joint.
I would strongly suggest using Titebond III or a similar waterproof glue. With proper glue application and correct clamping pressure, the glue joint will be stronger than the wood itself.
Oak is a poor choice for a countertop if food preparation will occur on it. The open grain will easily harbor bacteria and will be a real challenge to clean. Hopefully you're going to be using bar-top epoxy on it or something similar to seal it up as opposed to mineral oil butcher block finish.
Old 04-30-2011, 05:56 AM   #5
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Are you making this 3'x4' x 3" thick?
Biscuiting is for alignment. A solid glue joint (done properly)is stronger than a biscuit.
If you're going to biscuit, use a #20.
I would alternate your growth rings.
tcleve4911 is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Making wood garage doors. Daverimmer Building & Construction 9 01-26-2011 02:50 PM
Basement Decorative Wood Wall Cover popping up tk3000 Building & Construction 8 10-29-2010 12:17 PM
Help Need Wood identification :D x3 iloveusk8rboi Carpentry 3 10-15-2010 09:05 PM
wood trim when tiling counter ponch37300 Flooring 6 04-29-2009 06:47 PM
