#1 |
making a triangle work surface on an downward sloping tringle
i know this sounds a bit weird.....i need to make a triangle worksurface out of wood, but the catch is that it is on a downward sloping triangular wall....please help? how do i cut the wood so that one side is vertical to the floor while the top is parallel and yet the bottom follows the slope....and then join eveything at the tip of the triangle....
any help? thanks |
#2 | |
making a triangle work surface on an downward sloping tringleQuote:
| The Following User Says Thank You to del schisler For This Useful Post: | funathome (09-23-2010) |
#3 |
thanks, that was perfect. just one question. if i am going to cut 1.5m of 6x4cm batons- what is the best tool to use to cut the angle over the length? any tips? thanks again for the previous info.
#4 |
don't know how much 1.5m is or 6x4 cm is. I didn't look it up for conversion's. But just draw line . What tool's do you have . Any thing that will cut off what you don't want. Now if it is jagged edge you can use trim ??
| Display Modes | |
