Making Rough Opening Narrower?? - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-17-2011, 03:25 PM   #1
In a little over my head
Rewards Points: 706
Making rough opening narrower??
I'm using the old window opening and header as the rough opening for an interior door to a bathroom/addition. The old opening/header is 40" wide. the new opening is 30" wide (2'4" door). The door hinge will be on the existing jack stud. I've added a stud to make the opening narrower, on the striker side of the door opening. Would you double that stud to stiffen the RO, or can I add a block near the latch striker? The block would give me more room for electrical boxes for light switches. Or is just a single stud adequate? Thanks!
ratherbefishing is offline   Reply With Quote
Old 09-17-2011, 05:06 PM   #2
Msradell's Avatar
Rewards Points: 122
Since you really don't need this structural support a single stud within a block installed near the latch should be sufficient. That is unless you will have kids constantly slamming the door!
Msradell is offline   Reply With Quote
Old 09-20-2011, 04:25 PM   #3
Rewards Points: 706
Thanks. That's what I was thinking, too.
Old 09-25-2011, 07:37 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
i would double the stud where the striker will be, simply blocking it wont prevent the framing from moving around which in turn can allow the jamb to go out of alignment. when this occurs the door wont close properly
woodworkbykirk is offline   Reply With Quote
Old 09-26-2011, 09:48 PM   #5
Stairguy
Millertyme's Avatar
Rewards Points: 508
the 2x4 wont twist with drywall screwed to it
Millertyme is offline   Reply With Quote
Old 09-26-2011, 11:16 PM   #6
if the 2x4 is wet when its installed it can still twist, seen it a thousand times
Old 09-27-2011, 03:12 AM   #7
I would double it up, is stronger construction and gives you more to nail your trim into.
remember standard door framing, even with partition walls, there will be always at least 2 studs on each side of the opening. 1 stud seems a bit flimsy to me, even if you don't need to worry about supporting the header.
chrisBC is offline   Reply With Quote
Old 09-27-2011, 06:51 AM   #8
Stairguy
Millertyme's Avatar
Rewards Points: 508
good point about the trim.
The Following User Says Thank You to Millertyme For This Useful Post:
chrisBC (09-27-2011)
Old 09-27-2011, 04:57 PM   #9
another thing is that by laminating two studs they become stronger but also they will work against each other resisting twisting which keeps them straight
New rough opening to basement - spiral staircase benjamincall Building & Construction 8 07-16-2010 06:53 PM
Widen Rough Opening -- w/o a headache luvdairish Remodeling 7 06-11-2010 09:54 AM
Rough opening for door is 1/4" too small-what to do? Badfish740 Building & Construction 15 02-08-2009 11:05 PM
Finishing opening for closet Frank_N_Stein Carpentry 11 12-24-2008 09:52 PM
arched opening ITE Remodeling 5 12-09-2005 06:14 PM
