Making Room For Larger Fridge - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-12-2014, 04:50 PM   #1
mikevoth's Avatar
Rewards Points: 22
Making Room for larger Fridge
Bought an older house that had some tremendous cabinetry work done 35-40 years ago. The problem being, is that the kitchen cabinet on the wall and floor cabinet under the kitchen counter butt up flat against the partition that houses the fridge. All made around the small 30" wide opening for the small fridge. I had my cabinet guy come over and see if the cabinets can be modified (shortened) or have to be replaced. He said they could be modified so that the partition can be moved out to accommodate the standard 36" wide fridge with French doors. By the way, I'm replacing the counter myself while I'm at it. I haven't received his estimate yet, but I'm more than nervous to see it. For those of you with experience in this field, what should I expect to pay for such a job. It doesn't seem like that much work, but I haven't done woodworking before so I can't really say. Any info would be greatly appreciated. Thanks in advance!!
Mike
mikevoth is offline   Reply With Quote
Insulating a cold/well room? Lynch Building & Construction 23 07-25-2014 03:49 PM
making a wall to split a room show Remodeling 9 04-16-2012 02:41 PM
How big should a mechanical/utility room be? reveriereptile Building & Construction 30 03-14-2012 09:11 AM
Making an Interior Room Habitable Space HooKooDooKu Building & Construction 17 01-15-2011 11:23 AM
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 08:28 PM
