Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-28-2010, 07:26 AM   #1
making own crown molding
hope i am in the right section, if not please move to correction place.
i am getting ready to paint my living room and want to put up crown molding but my problem is that i have wood panels that i painted three years ago and would prefer not to tear them down. where it meets ceiling to wall there is a 9 in. gap that i covered with trim wall paper. decent job but the whole thing now is that i would like to put crown molding but the crown molding that would cover that space is way too expensive so i was wondering should i make my own crown molding by using 1in by 4in pine/oak and putting trimming on the bottom then crown on top leaving some space in between them. (like they do kitchen cabinets on top) sorry for the long story but try to put as much info as i could.
marin001 is offline   Reply With Quote
Old 03-28-2010, 08:21 AM   #2
Remodeling Contractor
sort of on the right track. you want to build up the molding profile using several standard stock trims. Look at some pictures from fireplace mantle catalogs for ideas. We make these the same way. making your own is not practical. crown comes in three spring angles. the angle to use depends on your height of the ceiling.
The Following User Says Thank You to Bob Mariani For This Useful Post:
marin001 (03-28-2010)
Old 03-28-2010, 02:43 PM   #3
As Bob said, you can use the layered approach to build up the profile you want. I don't understand why you would leave a space on top. The space in the kitchen is usually due to the cabinets being far from the ceiling.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
Old 03-28-2010, 10:13 PM   #4
Ron
sorry may i stated that part wrong, i meant right below that top part. there would'nt be any space. thanks for the replies.
Old 03-28-2010, 10:22 PM   #5
the reason is because i used to have a drop down ceiling, and the previous owner did'nt put the panel all the way up to the ceiling so they left about a 9 inch gap and the crown moulding that would cover that is just way too expensive and would be considered ''special order''
non returnable if i dont like it.
Old 03-28-2010, 11:15 PM   #6
just to give an idea of the direction i am looking to go see attached photo
upper left photo
Old 03-28-2010, 11:56 PM   #7
this is the kind of moulding i would like to install, could anybody tell me the name of this moulding
thank you in advance
Old 03-29-2010, 12:08 AM   #8
Jay123's Avatar
It's called.....crown... ... CR49 by the looks of it...maybe .50 - .60 a lin. ft.
It's the basic (but nice) stuff ya see all around...and available at HD and Lowe's .
J
Jay123 is offline   Reply With Quote
General crown molding tips for rookies. speedster1 Carpentry 5 02-16-2010 08:18 PM
Need help on Crown Molding on inset Trey Ceiling pacumming Carpentry 2 01-30-2010 01:13 AM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 11:52 AM
crown molding ponch37300 Carpentry 15 06-05-2009 03:35 PM
Paint Crown Molding Before or After Installation? gmhut Painting 24 06-03-2009 09:38 PM
