Making New Interior Sills - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-06-2011, 12:31 PM   #1
making new interior sills
First time back in a long time ( busy with diy now good weather is here).
My question is this. I have to make new interior sills for my bathroom and
they will need to be in excess of 8inches deep ( bull nose to window). If
I need to join two pieces of wood to do this what is the best way. Dowel, biscuit joiner and biscuits and glue? Any suggestions would be appreciated.
porchhen9 is offline   Reply With Quote
Old 06-06-2011, 03:01 PM   #2
kwikfishron's Avatar
Rewards Points: 814
Why would you need to join two pieces of wood? Use 1x10 and rip it to the size you need.
kwikfishron is online now   Reply With Quote
Old 06-06-2011, 03:56 PM   #3
Rewards Points: 5,336
Where is this window in the room? I try to avoid wood in this room if possible.
Ron
B. Franklin 1759
Old 06-08-2011, 03:57 PM   #4
Hi...the window is in my bathroom, it is not over or near the shower/tub.
The house is 140+ years old and lacked any kind of framing I could use. So I
had to install 2x4 framing for the electricals ( code here). That is why my inside sills are so deep. I could use 1x10 material, the original had a bull nose
and would like to replicate it if I can. Any suggestions on how to go about
this would be welcome. Would 1x material be thick enough to create a bull nose from? I bought a book on the subject of finish carpentry and they
suggested using 5/4 finished stock but I cant find that here.
Old 06-08-2011, 04:25 PM   #5
5/4 stock is pretty standard fair around here. Not 5/4x 10, but if you want the beefier look, just bisquit them together. Older houses had thicker trim you can't readily find today.
Ron
B. Franklin 1759
Old 06-08-2011, 06:27 PM   #6
Tom Struble's Avatar
Rewards Points: 2,002
on the inside they are called stools
Tom Struble is offline   Reply With Quote
Old 06-09-2011, 09:10 PM   #7
Yep I know they are called stools, I will probably go with biscuiting a piece
onto the front. Thanks guys you have been very helpful. I am learning as
I go along here. Never done anything on this scale before. I just couldnt
afford the high labour costs involved in renovating a bathroom.
The Following User Says Thank You to porchhen9 For This Useful Post:
Tom Struble (06-10-2011)
Making an old fireplace insert more efficient Bed Rock HVAC 2 10-10-2012 05:39 PM
Making a melamine box secutanudu Carpentry 15 06-20-2011 02:51 PM
Need help making a 'back band' around window/door casing. RickDel Carpentry 3 07-15-2010 03:13 PM
GE fridge (older model) motor(?) making a lot of noise as it runs, also leak! liileah Appliances 1 06-24-2008 11:32 AM
Making bear totum pole Keith of Ronin Landscaping & Lawn Care 2 03-27-2005 01:22 PM
